Where do I find the laser lens on a Sharb CD-BA1200 cd multi player
    Top Expert:
  • Audio Player... Master
  • 8,374 Answers
Are you on about the laser disc lens that reads the cd for it to play?
Method 1 Cleaning a CD Player
  1. Confirm there is no CD in the player. ...
  2. Blow away dust with a handheld air bulb. ...
  3. Remove the lens cover. ...
  4. Select a lint-free cleaner. ...
  5. Wipe a small amount of high-strength isopropyl alcohol onto the lens. ...
  6. Let dry before replacing the cover. ...
  7. Try a lens cleaner disc.
More items...
How to Clean a CD Player: 11 Steps - wikiHow
Posted on Dec 25, 2016
Denon c200 is not reading any CD's.
It is very possible that your Denon CD player needs to get the laser lens cleaned.
You can do it yourself taking the cover of and get to the laser lens and clean it.
Here is a site that shows you how to do:
http://www.wikihow.com/Clean-a-CD-Player
or you can purchase a laser lens cleaner CD:
http://www.amazon.com/Allsop-56500-CD-Laser-Lens-Cleaner/dp/B00000J1QK
Regards
Sep 12, 2011 | Denon Audio Players & Recorders
CD player will not recognise or play disc
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it not recognize or play disc.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Apr 05, 2011 | Sharp Multi-System Mini Component System...
My player is very selective about which DVD's it will play? I recently was given a DVD with movies burnt from a computor but it will NOT play?? It has been suggested that I try to make my player...
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck and take care.
Feb 26, 2011 | Sony BDP-S360 DVD Player
The player is not playing the cd is keep on saying reading
Good luck.
Jan 25, 2011 | RCA DRC500N Multi-disc DVD Player
When trying to play an audio cd ER appears on the screen model # 916 Thank you
Hello
The error code you are receiving is either due to a dirty laser lens, or a burnt out lens.
You can try to resolve the problem by cleaning the head of the laser lens using a ear bud with some surgical spirits, or you can try a laser lens cleaning CD.
If none of the above works, the laser lens itself is probably burnt out.
Please fell free to contact me if you need any further assistance.
Kind regards
Andrea
Nov 11, 2010 | Durabrand CD-85 Personal CD Player
My Sony MegaStorage CDP-CX455 400 Disc changer does not play CDs anymore. What can I do to fix it?
Pretty much the only thing you can try at home is cleaning the laser lens, if the cleaner works then remember to use it now and again.
If the CD lens cleaner does not work the take it to the nearest sony tech/dealer for repair. Multi CD systems are very complicated and need specialist attention.
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | Sony MegaStorage CDP-CX455 400-Disc CD...
Hi my cd player will play for a couple of tracks then start jumping have cleaned disk but to no availehow can i clean laser on a multi disk
multi-disk or single disc player has only one (1) lens (reader), so you can use those commercially available cd player lens cleaner. ( a disc with tiny brushes in it.)
Apr 30, 2010 | 2004 Land Rover FreeLander
KOSS CD player will not read CD says '' no disc
you need to Clean the laser lines inside the cd player I can do that for you if you want me to
Dec 20, 2007 | Audio Players & Recorders
The DVD player doesn't play DVD disc only CD discs
first thing to do is try a lens cleaner disk. If that does not help you can try to remove cover and maualy clean the laser pick up with a q-tip and isopal alcahol. If that is not something you want to try have it done by a friend that has experiance or a shop. If that does not fix it you will need a new laser assy.
Dec 03, 2007 | kawasaki SVP500 Multi-disc DVD Player
50 people viewed this question
 Grubhead
Grubhead
