Hi, my CS-E9LKR emits a foul smell. No longer drips water from drain pipe outside. I'm wondering how to try unblocking the drainage ? Any advice much appreciated. TIA
SOURCE: water is filling up in drain pain
My suggestion is to NOT pull the plug on the drain that should be covered with a sign that says...do not remove plug. Water is supposed to be kept in the pan. The interior wheel then helps the water keep the condenser cool....Ron
Posted on Sep 23, 2007
  • 659 Answers
SOURCE: daikin air conditioner leakin water at a fast rate
You should have access to the condensate drain from the outside. You can use compressed air to unclog the unit. If you can, try accessing the drain from the source outward but be careful, you can blow debris everywhere. Make sure you have something to catch it so it doesn't spray everywhere. If you don't have access to compressed air, you can use a small plumbing snake to work you way up the pipe. Hope this answers your question.
Posted on Mar 20, 2009
  • 400 Answers
SOURCE: My Daewoo DSB 091L unit has started to drip
Make sure that the flexible pipe is securely connected to the drainpan, it can come adrift and cause leaking. The way to check this is to make sure everything is dried out completely. Then open the front grill and carefully pour water so that it goes only into the drip pan. Pour slowly so that you do not overflow the pan. If water is coming out on the outside and you have no leaks on the inside, then you can rule out the perished or disconnected drainpipe theory. In this case your unit may be short of refrigerant causing excessive run time and a freeze up of the evaporator.
Posted on Mar 31, 2009
SOURCE: Whirlpool Air Con Drainage issue
Yes, there should be a place for the condensate to drain outside. It's apparently clogged and the drip pan is overfilling. Look for a tube or an opening outside where the condensate should be exiting. This needs to be unclogged.
Posted on May 31, 2009
  • 29 Answers
SOURCE: My splict ac system is not draining the water
try lifting the unit off the wall and making sure its level and flat against the wall so the water flows as it should in the tray
common install related problem
cheers
Posted on Jul 05, 2010
How to get rid of Dac8008ee light stench?
If you checked outside and it's not draining properly, try sticking wire with a pipe cleaner attached through pipe. Make sure wire is flexible enough to go through pipe and make sure pipe cleaner is secured. Or just try to blow compresed air through line.
Jun 11, 2014 | Danby DAC8008EE BASE PAN - DB90-01255B
I have godrej gda 902 water is not getting drain after its first cycle of process can any one tell me what might be the problem
The drainage pipe is blocked up. this is a common problem amongst washing machines. People forget to check the pockets before a wash and dirt and fibers start to get stuck inside of the pipes and soon it is blocked and will not drain or drains very slowly.
Solution is to take the machine outside and unhook the drainage pipe. most of the time the blockage is there and is easily removed.
If not, hook the machine up outside and when the drainage cycle is suppose to start try to see if the blockage can be removed by spraying high pressure water up where the pipe has been disconnected. The resulting push of water from both sides may be enough to breakup the materials blocking the pipe.
Apr 24, 2014 | Washing Machines
My washing machine does not drain water but is working fine. I do not know if the model has a pump as i do not have the manual & my drainage pipe is high
yes it has a pump.............
move machine to an outside door and let drain hose lay outside to get rid of some water........
remove back from machine...........the drain hose connects to the pump....
so .follow drain hose back to the pump then ........
see if you can open it up to unblock it.........
cheers
May 10, 2011 | Washing Machines
Water is dripping inside the refrigerator ... Model f23elite
hello about the water dripping from inside your fridge.inside your fridge there should be a drainage hole were the water should drain out ,it should lead to a pipe that leads down the back of your fridge.try unblocking the hole and pipe this should help the water run away more freely
Apr 23, 2011 | Whirlpool Refrigerators
Water is dripping from the inside unit and not coming out of the drainage pipe outside
The reason the water is coming out of the unit and not the drainage pipe outside is for a few possible reasons.
1 -the drain pipe is clogged / plugged (due to calcium build up,or frozen)
2- the line is kinked or blocked.
check the drain pipe carefully, there may be obstuctions.
Feb 21, 2011 | Heating & Cooling
The indoor split system is dripping water what can i do?
There should be a drain pipe to send the condensed moisture outside. Take the cover off the unit and check where the tray is and unblock the pipe.
Oct 05, 2010 | LG LSC121PMA Split System Air Conditioner
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
May 31, 2009 | Whirlpool Electronic Window Air...
My Daewoo DSB 091L unit has started to drip condensate from the casing joint underneath the front drainage tray. I have cleaned the blocked drain pipe and proved the water drains away. The condensate drip...
Mar 24, 2009 | Heating & Cooling
Daikin air conditioner leakin water at a fast rate
Mar 20, 2009 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
