Question about Homedics SBM 300H Shiatsu Massaging Cushion
My homedics SBM500HA won't switch on I've changed the fuse can anyone help
2 Suggested Answers
SOURCE: I've plug the 110-v Homedics massager into
I managed to get it fixed this weekend.
What I basically did was , I opened the cushion that was basically zipped up , then there was a plastic casing which was easily removable by unscrewing the screws.
then if you follow the power chord , you will find that it is attached to a pcb . This is the adapter. This adapter is then connected to another pcb through an easily removable power clip. What I did was I took this to an electrician . The whole unit looks like a laptop power adapter , but without tHe outer black casing. If you stay in bangalore you can take it to sp road, there's this shop that works on speakers. The electricitritian told me that a capacitor and something else , I don't remember , had blown up. He replaced it and it started working with a 120 / 220 volt 50 watt voltage converter. I have MCS-700H, check what is your power rating, its written the label which is in the seat of ur massager. If ur not sure buy one with 100 watts .
Hope this helps!
Btw it cost me 300 to repair and 200 for the voltage transformer.
Posted on Apr 02, 2012
97 chevy suburban AC clutch won't engage pressures
Looks like the low pressure switch gets power from a 10amp ac fuse. Power then goes to the ac relay which is powered on by the ac heat controller on the dash. Power then goes thru the high pressure switch to the compressor. The ac relay is grounded to the body. Do you have power on the lite and dark green wires going into the relay and is it grounded ?
Jul 26, 2013 | Cars & Trucks
1995 Isuzu Rodeo won't start all of a sudden.
Check connection battery,could be starter.
Jun 05, 2013 | Cars & Trucks
Brake lights won't turn on.
Try replacing your brake light switch. Located at the bottom by your brake pedal.
Mar 04, 2013 | 1999 Ford Windstar
Curvy 8770 won't turn on
here's a link for a free manual
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
I had other questions about the singer curvy,, check in the manual
to see if it has a hidden fuse.
if it doens't have a fuse, the it could be the power cord or the
on & off switch
Sep 27, 2012 | Singer Curvy 8770 Electronic Sewing...
Brake Lights Won't Light?!
Have you checked the brake light switch by the brake pedal?
Jun 20, 2012 | Cars & Trucks
Head light not working
I was having the exact same problem. Changed out the fuse like the guy above said and all is well. However, in my investigation, I pulled the fuse for the passenger side and all the lights went out. Weird. Not sure what that was about. Put it back in and they all came back on.
Apr 24, 2012 | 2004 Subaru Impreza
Daughters Car Won't Start
did u disconnect he ground on the battery,berfore changing th swicth, ther are two fuses / relay . one under dash and one under hood. if ther good ther is a back up fuse to comp. 7.5 read cover to be sure . take out for 10 min. replace and see if it helpes if not u may hav melted wires somewere. solenoid to to starter. good luk claymister
Dec 01, 2011 | 1990 Ford Thunderbird
My slk 2000 roof has just stopped working. It wont go down at al
Sounds like maybe some pin switches for interlocks have gone bad. Open your trunk and look for the rubber booted switches and try holding them or shorting them, if you make the top move it shows you which ones are bad.
Jul 16, 2009 | 1999 Mercedes-Benz SLK
Ilectrical problem
If I only used it for 10 min. and it stopped working? I would quickly throw it back in the box and find a store that sells them and demand a replacement. Or just buy the same exact model and then return the broken one to the store with the same reciept.
Jan 01, 2009 | Homedics SBM 300H Therapist Select Shiatsu...
Homedics SBM 300H Shiatsu Massaging Cushion Logo
19 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
