Question about The Watches
What direction do I turn the back of an Ingersoll watch to remove it
  • The Master
  • 18,419 Answers
Posted on Dec 25, 2016
Replace the battery in an ingersoll japan movement
I expect the battery will be where it is to be found in most other watches. Remove the back of the case and the battery should be fairly simple to access.
Oct 21, 2017 | The Watches
How do i manually wind my ingersoll automatic watch. It stopped after wo days of not wearing the watch
Shake it. It winds from the movement of your arm. A few good shakes should restart it.
Jul 07, 2016 | Watches
How do I change the battery on fossil motorcycle clock?
You will need a very small (watch or glasses) Philips head screwdriver, and a SR626SW (or know as a 377) watch battery.
Remove screw 1 to remove the motorcycle back cover.
Remove the other 2 screws to take off the clock backing.
Remove the white plastic ring by pulling directly up.
Remove the battery.
Put the new battery in.
Press the white plastic ring back on.
Reassemble the clock backing with the two screws.
Reassemble the back of the motorcycle with screw 1.
May 24, 2012 | Watches
I recently took my fathers ingersoll duo watch to a repair shop to have new batteries installed unfortunately they were unable to separate it and get inside. could you please tell me how to do this.
I wouldn't advise you to do it yourself, as without special tools and knowledge you will just damage that watch. The best way is to type in your browser: watch repairs + your area. You should find plenty of them there. Contact by phone first and explain what sort of watch you do have and what's needed to do. Ask watch repairer on the phone, because only him/her will be able to understand specific needs. Do not explain to manager or just personell - they are useless. When you are satisfied with the answer over the phone, go there and give your watch for whatever it needs.
Jun 02, 2011 | Watches
Shorten the band on a Mossimo watch
Thank you for contacting FixYa.
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Sep 15, 2010 | Bulova Watch
    How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    Can't figure out how to revove links to make it the proper size
    locate the arrows on the inside of the watch, use a push pin and small hammer, and lightly tap the push pin into the groove while bracing it on both sides so the pin has room to come out. Make sure the direction you are hammering is the same direction the arrow points. The pins inside are tapered, and will only come out in the one direction. Do this on two of the pins to remove one link, or leave one pin between the two being removed to remove two links. Put the watch back together by reversing the first step. Hope that helps!
    Dec 23, 2009 | TechnoMarine Square Ceramique SQCB02C...
    I just bought a fossil watch ch2331 and need to remove a link. how do i do it?
    Some of the links are removable on this watch & some are not. Look inside the band you should see some tiny arrows on the removeable links. You need to push the pin through in the direction of the arrows & remove the link. Then to put the band back together you need push the pin through in the opposite direction of the arrow. Make sure the widest part to the pin goes in last or it won't fit.
    Mar 09, 2008 | Fossil CH2331 Wrist Watch
    Watches Logo
    Top The Watches Experts
    D. E. Hev
    John mullen
    Are you a The Watch Expert? Answer questions, earn points and help others
