Question about Garden
What does the knob on the side of the ac trimmer serve as?
How do I get off the bump knob
Depends on the make and model which you haven't stated. Some unscrew, some have 2 clips that you push in, on the side of the trimmer head. But different models vary.
May 19, 2016 | Garden
Toro tb65ss upper string head removal
  1. Pull the spark plug wire from the top of the spark plug. Bend the wire to the side to prevent accidental starting.
  2. Place trimmer on its side with the trimmer spool head facing you. Press the two tabs on the side of the spool head with your fingers.
  1. Hold side of the head and slowly allow the head cover to push away from the inside of the spool head. There is a spring between the spool head housing and the spool that pushes out when releasing the cover.
  1. Pll the knob and spool out of the spool head. The spring should come out on the back of the spool.
    Electric Trimmer
  1. 1 --> Unplug the Toro trimmer power cord from the electrical outlet.
  2. 2 --> Lay the trimmer on its side. Hold the spool housing tight in one hand and twist the cap counterclockwise with your fingers. If necessary, use a pair of large slip joint pliers to start turning the cap. The cap is the center piece of the spool.
  3. 3 --> Pull the cap off the spool and remove the spool from the housing.
Apr 26, 2014 | Garden
How to lock shaft to change blade on atom turbo 301 lawn edger
hello, To keep the shaft or trimmer head from turning when trying to remove the bump knob or blade insert a screwdriver in the slot on the other side of the head and remove bump knob or blade,hope this helps,,
Feb 13, 2012 | Garden
How to change blade on atom turbo 301 lawn edger
hello, To keep the shaft or trimmer head from turning when trying to remove the bump knob or blade insert a screwdriver in the slot on the other side of the head and remove bump knob or blade,hope this helps,~~
I think I need replace the laser lens. I would like to do it myself, as no local electronics stores will do it for less than what it would cost to buy a new DVD player. Could someone point me in the right...
Those BRANDED DVD player usually got problem on dirty contacts of the LENS!
Try this, remove the cover, look at the side of the LENS, there 2 TRiMMER KNOB, use a prectssion screw driver that could adjust the trimmer, mark the trimmer before adjusting it, the one that has a mark of "D" is for the DVD, using the screw driver play the trimmer by adjusting it side-by-side, return the trimmer to its original position... then check it, it always works!
Nov 27, 2010 | Philips HTS-3555 System
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Parts list tanaka hedge trimmer
You can get the service manual on link below.
http://tanakapowerequipment.com/pdf/serv/Tanaka_HT_Service_Manual.pdf
On this link below is the parts list.
http://www.tanaka-usa.com/pdf/dpl/hedge_trimmers/THT-2100dpl.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Toro& Electric String Trimmer: how do you take the bottom part off?...
Look for a couple small windows on the sides of the center knob that sticks out, push in on these, they are tabs that hold the center knob on, after that the string bobbin should slip right out.
May 17, 2010 | Toro& Electric String Trimmer
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
