What causes the tv not respond to the remote, have the light on even after we've turned off, tv turned on mute and can't change the channel or switch to other apps. Turned the power off and restarted.
    Top Expert:
  • Televison & ... Master
  • 73,619 Answers
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Posted on Dec 25, 2016
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
Make sure your TV is turned on.
Slide the mode switch at top of remote to "TV".
Press and hold the MUTE button. This is located above the number 1 button.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
Then enter 9911, the green light on remote should flash twice.
Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
I need the code for a sharp tv on a guestvision universal remote?
Probably your best bet would be to perform a channel search. Make sure the TV is on and press and hold down the "Code Search" button. After the red light comes on, begin pressing Channel Up until the TV responds. This could take a very long time, but should eventually work. Once the channel changes on the TV, go ahead and press the mute button on the remote and you should be set!
Aug 25, 2011 | Televison & Video
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Mar 08, 2010 | Televison & Video
My tv turned on on its own and does not respond to the remote, even after replacing the batteries. Furthermore, the volume goes up to 100 and down to zero on its own and the remote is not able to control...
check remote first,how to check remote switch on your camera phone point to camera lens,when press any key check screen light glow,you sure r/c ok.next check reciver eye of tv
Jun 27, 2009 | LG 32LC7D Television
My samsung tv is not responding to my remote control, actually even when I go and attempt to change the channel from pressing the up/down buttons on the tv it won't respons, some menu screen would come on...
your turning section is not responding to any input, hence needs to be checked by a technician. every thing you have mentioned are controlled by one ic, with its respective voltages.
Mar 21, 2009 | Samsung Remote Control
Both TiVo and Vizio remote aren't working right. Has to be TV.
my remote is not responding to new battery not showing green light.
Nov 16, 2008 | Vizio L32 32 in. LCD HDTV
Need help programing a RCA NITEglo remote cantrol
This remote was also supplied by RCA for their VHS player, model # VR629HF.
The instructions to program it can be found in the user manual for the VHS player:
http://www.retrevo.com/support/RCA-VR629HF-VCRs-manual/id/19241ag112/t/2/
1-Turn on the TV
2-Find the brand and code number(s) on the code list on the next page
3-Press and hold the TV button on the remote.
4-Enter the code from the code list.
5-Release TV, and then press CHAN up or down. If the TV responds to the remote commands,the remote is programmed.
6-If the TV does not respond, repeat these steps using the next code in the list.
Nov 14, 2008 | Televison & Video
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
