Question about Bose Audio Players & Recorders
While charging my Bose quietcomfort 20 in ear headphones the red light stays on?
SOURCE: the bose quietcomfort 2 earphones
I've noticed a second or two of silence when bumping the headphone. In my case the battery was low and a fresh battery fixed this particular problem. Or maybe you have a poor connection.
Posted on Oct 28, 2008
M2Tech1
  • 313 Answers
SOURCE: Jack / Cord problem
yes basically if you look at the jack end you should see where the join is it may unsrew then look at the wires in side and the looose one should be seen if not yu can get a new jack from most online electronics Maplin -RS- or any electronics supplier you will need to resolder the wires onto the new connector..make sure you keep the other snipped off connector for reference when resoldering new.. There are a few tips to soldering.. maker sure the wire is twisted before soldering and touch the wire to the solder tip then bring teh solder wire to the wire to tin (melt solder) the end then do the same with other wires. once the wires are tinned bring to plate on teh connector and touch wire to connector and then solder tip to where wire and connector are.. if you keep teh soldering iron on the connection to long you may melt the plastic jack surround so I usually use a metal jack type.. if it has three wires one is for left one for right and one earth..copy the old jack wiring and you should be ok.. Good Luck A
Posted on Aug 04, 2009
  • 1138 Answers
SOURCE: The left earbud of my Bose in-ear headphones doesn't have sound
You probably need to replace the stereo plug on the end that goes into the jack. Most of them are molded on unfortunately but it can be done with a new jack and some soldering skills. There have been lots of people with the same problem on this site so there are already some good explanations of how to do this on here.
Posted on Aug 28, 2009
cseian
  • 138 Answers
SOURCE: The sound coming from my right bose on-ear headphones
i think ur headphone wires or its pin at end will be defective..
99%there is no chance of failures in speakers ..
try to replace ur headphone cable with new cable.
just solder the cable with speaker inline pins..
Posted on May 25, 2010
tbreeze47
  • 3083 Answers
SOURCE: my bose in ear headphones
You will have to strip back enough wire length on the wires and also on the jack (or a good new and used jack with wires coming out of it) and wrap or solder them together, then wrap them in tape or coat with nail polish, and tape when they dry. Sometimes it just won't work, sometimes it can, just depends. Since the wires are usually multiwired and lacquer-coated, it is tricky and very hard. You have to separate the thin cloth fibers used for strength, and then scrape the lacquer off with an exacto knife, scraping the ends repeatedly. It's a delicate and hard operation. After the lacquer is off, wrap the ends together, or carefully solder if you can. Be careful soldering, since it's easy to burn up the super thin wires with too much heat.
These items are not designed or built to be fixed, or serviced, but sometimes you can get lucky. I used to do it, but it's a **** shoot whether it will really work, is tedious and takes awhile, and then there's no guarantee how long .
Good luck, wish there was better or easier news.
Posted on Aug 17, 2010
Severe squelch in left ear phone
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a significant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the shape of the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
If the foam in the ear cushion has weakened/deteriorated to the point that it no longer has it's original shape, (in particular the lower half of the ear cushion), the size and shape of the air chamber inside of the earcup is directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
It is probably time to replace the ear cushions. If so, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Aug 29, 2013 | Bose QuietComfort 3 Acoustic Noise...
How to replace ear cushion on bose QC 3 headphone
The ear cushions are held on the earcup with six snap fasteners, three on each side. To remove the ear cushion, simply pull it away from the earcup carefully so that you do not break the plastic snap tabs.
It should not be necessary to pry the ear cushion off with a sharp object, but if you do, be careful. There is also a thin gasket seal between the earcup and the ear cushion, take care not to damage it.
If you need to replace the ear cushions with new ones, they are available from Bose for $35/pair.
or $5.69/pair.
Apr 02, 2013 | Bose QuietComfort 3 Acoustic Noise...
Bose headset not working
bose headset is not working the red light is not on
Jan 04, 2013 | Bose QuietComfort 3 Acoustic Noise...
My headphone, once side where the ear cup joiner with the top bit was broken. Can I get it fix? Thanks
Call Bose 1-800-999-2673 they sell replacment ear cushions for the QC3 I paid $38 for two.
Nov 28, 2011 | Bose QuietComfort 3 Acoustic Noise...
My QC3 make a loud whistling noise like a tea pot is boiling. I have changed my Ear Cups but thats it. I thought at first there was air entering from the small holes or that my battery was almost dead....
that happened to me when i was at the beach and had wind blowing. it stayed for several days but it seems to have gone after it was left with the battery disconnected for a few days .i would get them replaced under the Bose replacement program for $100 us
Mar 07, 2011 | Bose QuietComfort 3 Acoustic Noise...
Bose QC 2 Noise Cancelling Headphones the red light is on. Should there be a green light if they are working?
No green light for QC2, just red. If it's constant the battery is charged, powering the noise cancellation, and, if connected to an audio device, conducting sound. If the red light is blinking, the battery is losing its charge.
Nov 18, 2010 | Bose ® QuietComfort® 2 Acoustic...
My left ear headset does not work. the right one is fine and the battery is charged,
sounds as if you have a short in the left ear. solution would be to send in to manufacture. Or return to the store.
Oct 04, 2010 | Bose QuietComfort 3 Acoustic Noise...
Red light flickers for a few seconds on Bose headphones. They have been charged overnight, and were working well yesterday? I've cleaned the removable plug, and if I jiggle them sometimes they'll connect...
How old are they? It seems like 3 years is the life expectancy for any electronics these days whether it be notebooks, mp3's etc. Someone said call Bose and they will send you new ones for $75. Mine are doing the same exact thing yours are. Im calling tomorrow!
Nov 13, 2009 | Bose QuietComfort 3 Acoustic Noise...
Bose QuietComfort2 Acoustic Noise Cancelling Headphones not working
same thing has happend to me, sometimes when im playing around with it i get about 2 hours use before it turns off again. do you recon its worth sending it off to bose for repair?
Oct 05, 2007 | Apple Bose QuietComfort 2 Acoustic Noise...
Less sound on one ear than the other
Yeah, based on all of your problems, i would safely say that you have a blown speaker. Call up Bose at 1-800-999-2673. If the headphones are under warranty (1 year) they will replace them for free. If now, they will charge you $100 for a replacement pair, which is quite a deal considering that the headphones cost $300.
Jul 05, 2007 | Bose QuietComfort 2 Consumer Headphones
41 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
