Question about Tools & Hardware - Others
My metal lathe top_tech .c0632c main feed dont want to work can you help me
3 Suggested Answers
  • 98 Answers
SOURCE: dont know how to manually feed paper
Follow instructions on the following link (look in the Manual Feeding section of the document): Good luck, hope it helps.
Posted on Aug 22, 2007
SOURCE: I need a manual for
I have the lathe and got a manual emailed to me from the jet people since it doesn't show on their web page. I just called them off the contact us link.
Posted on Sep 17, 2011
Problems with grando 0 go sf 262 washing machine
see this and fix it. God bless you
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
Sep 27, 2012 | Candy Washing Machines
I have an aamco 4000 brake lathe, the disc feed is not working
The cross feed drive shaft is connected to the cross feed spindle via a coupling that resembles a universal joint that is threaded onto the end of the cross feed spindle. Either one of the roll pin holes in the drive shaft coupling has worn and the roll pin fell out or it has broken, or the coupling could have came un-screwed from the cross feed spindle. Remove the 4 bolts that hold the cross feed gearbox on and slowly pull it away from the machine and you should see the coupling I'm describing. My guess is that the roll pin broke or fell out due to wear. You can buy a new drive shaft and coupling or drill and install the next larger roll pin. Either way you should download a parts list for your machine. Just search for it, they can be downloaded free.
Aug 22, 2012 | Ammco Combination Disc/Drum Brake Lathe
Not enough rigidity, wrong speed, wrong feed rate, wrong depth of cut, wrong or dull tooling...
Feb 03, 2012 | Ammco Combination Disc/Drum Brake Lathe
Most likely you have a stripped out "disc feed screw."
This is a common problem I see several times a month in the field.
The stripped out portion of the screw is near the end of the feed range obviously.
If you need parts or more questions answered....
Buy Sell Used Brake Lathes Brake Lathe Parts
Jan 22, 2012 | Ammco Combination Disc/Drum Brake Lathe
Instructions for changing an ammco 3000 brake lathe to a 4000. Parts needed?
Yes, an Ammco 3000 brake lathe can be converted over to a 4000 model--most any year 3000.... preferably the later years after 1970.
The problem with some of the early 60's models is that the cross-feed bore is not perfectly perpendicular to the spindle.
If you convert one of these models, you will cut the rotor at an angle and then jam the machine.
Later models can easily be converted.
You will need...
1) A complete disc feed gearbox.
2) A driven pulley (the big one) set-up for a with a pin drive.
3) A complete spindle lock assembly for the Infimatic gearbox.
4) Possibly need a longer guide bar for the cross-freed. If you have a round guide bar, this is possibly long enough. If you have a "Double-D" guide bar (flat on each side), you most likely will need a longer bar.
5) A complete twin-cutter, with tool guides, tool holders, knobs, etc.
We have all the parts you need for a conversion--or we can convert it expertly for you...
Aug 03, 2011 | Ammco Combination Disc/Drum Brake Lathe
Replaced belt on 4000 lathe and now I have no fast feed.
I think that you really need to source the manual for that machine.
Nov 27, 2010 | Ammco Combination Disc/Drum Brake Lathe
The problem isn't clearly explained. but the main shaft bearings go bad after awhile and it's one day thier good the next job their bad.
May 13, 2010 | Ammco Combination Disc/Drum Brake Lathe
Screeching in right rear wheel ,sound stops when breaks applied
its the brake pad wear indicator telling you your pads are in need of replacing
Sep 09, 2009 | 2006 Kia Sedona
Tools & Hardware - Others Logo
44 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
