Question about Cell Phones
How do I turn the speaker on when it doesn't want to turn on and how do I charge it when it doesn't want to charge
My speakers don't want to turn on
Hi ,
Sometimes , new speakers just don't work from the beginning and you need to bring them back to the retail shop under waranty .
Before doing that , check your soundcard by connecting it's output to another sound set , like your hifi or another speakers set . If this doesn't work , you could be just facing a driver issue that can easily be solved by downloading and installing the correct driver from the manufacturer's site .
Feb 09, 2013 | HP Harmon Kardon 5187-2105 Computer...
Some Hardware Problems of iPhone
Many of you may have little problems with the hardware of your iPhone. Here summarized as follows a few common fault and approach of iPhone. Hope it can help you!
Q: The home button doesn't work well, how to fix it?
A: Tearing down the Phone and use Alcohol to clean the contact of home button.
Q: Since I have dropped my phone, the voice of speaker is very low.
A: First you can try to clean the Metal mesh where the sound comes out; dust filter mesh can turn down the voice. If it doesn't work, you need to replace the speaker assembly.
Q: People cannot hear the voice from my phone after I have dropped my phone. But I can hear the voice from them. Does the telephone transmitter broken?
A: Try hands free. If people still cannot hear you, that's the problem of telephone transmitter. You need to replace interface.
Q: The Wi-Fi poor Soldering, how can I solve it without teardown?
A: There is no way in addition to tear down the phone and Solder again.
Q: After replace the screen, I cannot open the front camera although using a new camera; does the main board get some problem?
A: Check the resistance around then camera by multimeter, basically, the problems are short circuit or damage resistance
Q: My phone cannot charge when it was power on. But it can charge when the phone was turn off or connect to the PC. The charger and data line are OK.
A: Need to replace interface or clean the interface by degreasing cotton dipped in anhydrous alcohol.
on Sep 09, 2015 | Apple iPhone Cell Phones
I have a brand new i335 but when i want to charge it it doesn't turn on
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 10, 2012 | Nextel i355
How to fix a Samson XP40iw Speaker PA System
Have you checked the cables? If that doesn't fix it, you probably have a loose connection inside between the "mixer" unit and "amp" unit
Jul 23, 2012 | Samson XP40iw Speaker PA System
Loose jack connection to speaker
It sounds like you need to get a new jack socket and replace it. It could be just a soldering problem. Especially if you have removed the plug a lot in the past.
Jan 06, 2018 | Edifier Audio Players & Recorders
My ipod touch will not charge on my Zepplin, it did until recently but now it says it doesn't support charging
happened on mine, just try cleaning out the dock on the speaker and in your ipod and move the plug socket, hope this helps :)
Aug 09, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
Sound doesn't work tried settings tried turning it up ect can't hear ring tones nothing. when speaker is on when talking to someone it doesn't work.
seems your ringer (Speaker) got damage you have to replace them, install a new speaker and your phone would ring back again.
please vote me if found helpfull.
Aug 04, 2011 | Samsung Gravity SGH-T459 Cell Phone
Ihome ip87 it wont turn on it only charge my itouch?
If unit is plugged in and doesn't respond, try resetting the unit by
following these steps:
a) remove iPhone/iPod from dock
b) unplug unit from power source
c) remove back up batteries
d) wait 1 hour, then resume use
Jun 03, 2011 | SDI iHome2Go (IH80B) (Black) Docking...
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
