Question about Roku Televison & Video
My roku streaming stick remote just stopped working the green light dose not come on when i put new batteries in it what can i do to fix this problum
  • 6 Answers
SOURCE: dvd remote stopped working
open up your remote then separate the rubber / key pads then clean the cercuit using home dry cleaner and leave to dry close your remote gently and its fresh again. reason for this is practice is because moist cause cover between pads and circuit board and thus no contact then no function
Posted on Jul 27, 2007
  • 4 Answers
SOURCE: Remote stopped working
http://www.fixya.com/support/t320518-bose_321
Posted on Jan 13, 2008
SOURCE: Wii Remote Control Stopped Working
This happened to my son. I did some reading and found out you have to resynchronize the remote. This is from the manual
1) Press the Power button on the Wii console to turn it on.
2)Remove th battery cover on the back of the remote and press the SYNC. button inside the cover. The Player LEDs will blink.
3)Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment
4)When the Player LED blinking stops,connection is complete. The LED that is illuminated indicates the player number.
This procedure must be followed for each additional Wii remote added to your system.
This worked for me, hope it helps you.
Posted on Oct 03, 2008
stevenhurc
  • 450 Answers
SOURCE: remote key lock stopped working after wal mart put new battery in and now my head lights stopped workin!!!
check fuse for low beam, then possibly both low beam globes. they could have blown.
the key remote may need reprograming into system try put key in ignition in on position then press remote buttons a couple of times then try if no good need to go to dealer to be programed into system again or it needs repairing/replacing.
Posted on May 31, 2009
swolfinor
  • 504 Answers
SOURCE: chamberlain remote has stopped working, new
WHEN YOU CHANGE THE BATTERY NO NEED TO REPROGRAM THE REMOTE.
THE FLASHING LIGHT TELLS YOU IT IS SENDING A SIGNAL THAT IS BEING RECIEVED IT IS JUST NOT THE CORRECT CODE TO OPEN THE DOOR.
REPROGRAMING THE REMOTE SHOULD SOLVE THE PROBLEM
HOPE THIS HELPS
Posted on May 27, 2010
My roku remote is flashing green and wont work with new batteries
The Roku remote needs to re-paired with the Roku Player.
Open the Battery case on the Roku remote (Roku 4 remotes) look for a button and hold for 2 seconds this will then sync it to the Roku player.
Jul 09, 2016 | Roku Streaming Stick
My roku remote doesnt seem to be working
The batteries and either low or dead, or the Remote needs to be Re-paired with the player (Roku 3 and Roku 4). Open the battery cover on the remote and look for a small button and hold it for 2 seconds, this should make it start to resync with the Roku Player.
Jun 22, 2016 | Roku Streaming Stick HDMI Version
Roku remote will not work roku on screen but remote not responding. Green lite flashes on but voes right off but only sometimes.
I presume you have a box and not a stream stick.Try unplugging ROKU box.Many units have a button you have to push on remote after plugging in ROKU box,this connect Remote to ROKU box.If this doesn't work take out batteries in remote and put back in,this has to be done after you plug in ROKU box.Are batteries weak,try some new ones?
Feb 06, 2016 | Roku Televison & Video
ROKU STICK IS NOT STARTING AUTOMATICALLY.
Check plug in roku stick and in electrical outlet for a good connection pull out and push back in..Their is a small reset button on ROKU,push it ,it will then show a blinking white light,if not you may have a bad roku stick.
Hook up ROKU stick BEFORE you put batteries in remote,after you put in batteries you will have to push button near batteries.
The remote should start blinking a green light this means it is trying to pair up with roku stick.If it does a purple sceen will appear on tv.Push home button remote and tv should give you a code.This code has to be entered at ROKU site link on computer.
Jan 29, 2016 | Roku Streaming Stick
My Roko is frozen my remote is not working on the screen it say let's get started I push the button and nothing happens we have changed the batteries we do not know what to do can you help please
Roku Remotes Information & Troubleshooting - Roku Support
https://support.roku.com/.../208755708-Roku-Remotes-Infor...
Roku, Inc.Roku Remotes Information & Troubleshooting. Button functions & universal remoteinfo ... My remote is not responding - Troubleshooting steps .... ROKU POWERED, the ROKU READY logo, "Streaming Stick," "HAPPY STREAMING" and "NOW ...
Roku How To: Roku Remote Stopped Working - Easy Solution
rokuhowto.blogspot.com/2013/.../roku-remote-stopped-working-easy.ht...
Mar 10, 2013 - Remote working again AND I have the remote app on my phone. .....I've come to the conclusion that the Roku Streaming Stick is just a pile of ...
Roku Streaming Stick Remote Control Issues.... - General ...
emby.media > Emby Community > General > General Discussion
Jan 17, 2016 | Roku Streaming Stick
My remote is not working
You have to hook up roku box BEFORE YOU PUT IN BATTERIES IN remote.Make sure batteries are making a good connection try rotating batteries or try new batteries.Some ROKU models have a button in remote next to batteries. this has to pushed to connect to ROKU box.
Jan 01, 2016 | Roku 3
How can I jail brake it
Roku Streaming Stick® (HDMI® Version) (Model 3500 ...
https://support.roku.com/.../208754808-Roku-Streaming-Stick...
Roku, Inc.Connect your player Step 1: Insert the Roku Streaming Stick (HDMI Version) (Model 3500) into an available HDMI port of the TV. ...Missing: jailbreak
Roku® Streaming Stick® offers all the channels through HDMI
https://www.roku.com/products/streaming-stick
Roku, Inc.The small size of the Roku® Streaming Stick® means you can easily plug it into just about any TV with HDMI® and start streaming your favorite content. ... (for remote); USB power cable + wall adapter; Get started guide; Special content offers.Missing: jailbreak
Roku Streaming Stick channels - YouTube
Dec 15, 2015 | Roku Streaming Stick HDMI Version
What is pair your remote stick roku
Pairing usually refers to the Remote control. If your roku remote control is already working, you can ignore this.
Aug 05, 2014 | Roku Streaming Stick
Why doesn't my ROKU streaming stick work on this TV?
If you are cornered and baffled over which streaming device to purchase, you need to examine the new Roku streaming stick. We have created this article simply for you to let you know the features of the Roku streaming stick which best suits users streaming needs. We are on an online informative service too to help Roku users get the best info and assistance on almost all of their streaming players and other technical assistance.
The new Roku streaming stick is recognized as among the finest devices you could discover at this lowest price for the features it offers. The "Private listening" feature is usually accessible on the Roku streaming stick, allows users to automatically mute the particular TV's audio tracks and listen closely to the sound through the private hearing jacks provided along with device package. The user can also use this same feature through their mobile remote app.
The app seems to be well sync with these new new Roku streaming stick and found to be much efficient with this device. Although the developers say it is about the same streaming speed since the Roku 2. If you are seeking for that most effective "ac" Wi-Fi standard, which an individual can anticipate finding in the Roku 4 and Chromecast, then you are about to be disappointed. The remote features finds to more responsive and is incredibly very good and quick.
The Roku device takes about 28 seconds to get it powered, which often is quicker than its peer brand names like Chromecast and Amazon Fire TV stick. They perfectly suit into the HDMI plug-ins of all most every TVs. In the event if the user find an problem in fitting them to the TV then use the Power cable to perform the trick. Attempt to make use of the port saver, if the connection to the TV is not appropriate or too tight. The user should never overlook using the remote app, which allows streaming easier for Roku users.
Hope this article let you understand the features and functionalities of Roku Streaming Stick. In case of any assistance required on purchasing or activation of these Roku products users can contact our team experts for instant and reliable technical solutions. Users can contact us through the toll free number at +1-888-269-1011 or visit www.go-roku.com.
Aug 03, 2014 | Televison & Video
Set up problem
If you're using an IR remote, try to change the batteries. If you have a Roku 3 player, make sure to pair the Roku remote with the unit. You can refer to this link http://support.roku.com/entries/23486778-How-Do-I-Pair-the-Enhanced-Game-Remote-to-my-Streaming-Stick- ... if you don't have a streaming stick, you can still use the same link. They have the same concept.
Dec 15, 2013 | Roku Televison & Video
Televison & Video Logo
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
