My singing machine karaoke device displays "op". I've opened and closed the door several times to be sure it's fully closed but it still displays the same.
SOURCE: 2006 town and country passanger sliding door problem
I've leased two Town and Country vans over the past 4 years, and actually purchased the latest one after the lease. In both vans the sliding doors, normally the drivers side, reacted teh same way. If the door was closed it would open, stop a one point, and then return to the open position. At times I could get it close. But over time the doors stoped working all together.
It is not due to the switch or the motor. Most cases like this (in in both of mine) it is due to the repetitive use of that door, and the realitive inflexibility of the wire harness. Over time, and with more uses (in my case the driver side sliding door was used alot) the wire in the harness fails. Picture it as a willow branch. One snapped off of a tree it first is green and flexible, and bends pretty well into any form. But over time, with age and repetitive bending, it will break.
The only recourse is a new harness, as the wire/wires are broken somewhere in the harness (the belt chain in the lower track of the door). I was temped to take it apart and try to repair it myself, but as the parts were under warranty (I have the extended 85,000 mile), I opted to have the professionals handle it. The repair without the warranty is under $200 typically (parts and labor). Good luck.
Posted on Oct 09, 2008
CRTN
  • 716 Answers
SOURCE: ''Back door open, please close back door'' - back door is closed
This Error Is Reoccurring On All These Units Open Close Back Door Then Unplug For 30 Seconds And Then Plug It Back In. Check For Error.
The Brother Website Says To Check The Paper But Almost All Of These People Have Checked For Paper Problems And For Jams With No Result.
Posted on Jan 14, 2009
  • 6 Answers
SOURCE: LG Washer dryer error dE
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
Posted on Apr 12, 2009
  • 3197 Answers
SOURCE: Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Posted on Sep 12, 2009
  • 49 Answers
SOURCE: Door on left side wont open
not much you can do about this. I've had mine apart and it seems the belt (rubber band-like) are weak or stretched. This is a weak spot on this unit.
Posted on Nov 16, 2009
Won't play the CD and the open cover door won't go off when you close the door
Normally in all CD players there is a little "pip" in the door that presses a S/W when you close it. this may may brokend
May 14, 2015 | Singing Machine The iSM1028Xa Pedestal CDG...
Mic doesn't work
Hi Troy,
Have you inserted the mic in the right input? Make sure it is not inserted in the headphones input. Besides that take a look at the display menu and make sure the volume is turned on.
Mar 09, 2010 | The Singing Machine SINGING MACHINE...
Cd door will only half open
Just bought a singing machine ism 1028 Karaoke Vision from Costco. It was a floor model and when We turned it on it only shows to flashing bars in the CD area. Won't play demo CD. Nothing else seems to come on either. I have tried to look for manual on line and am unable to find one. Not sure if i have hooked it up right or if I have all the parts. Help please.
Nov 13, 2009 | The Singing Machine DVD/CDG Karaoke System...
No Disc Error
there is no fix you bought someone else's junk
May 08, 2017 | The Singing Machine DVD/CDG Karaoke System...
Karaoke machine wont play cds
I'm having the same problem with mine! As soon as I figure it out, I'll let you know...
Oct 20, 2008 | B&W 5.5" TV/CD+G Monitor Karaoke Machine...
Singing machine SMG 301 problem
has a bad drive motor, not sure where you can get parts for these
Oct 19, 2008 | The Singing Machine DVD/CDG Karaoke System...
Purchased JM258 Karaoke machine and led displays E when trying to play CD
The lid of the CD player was loose resulting in the CD not being able to play. If I hold the lid closed or place a book on it it will play. Needless to say, I will be exchanging it for one that works properly.
Sep 14, 2008 | The Singing Machine DVD/CDG Karaoke System...
Display keeps saying door
When your site kicked me out and charged me twice, I through the singing machine away! that solved the problem.
Jul 04, 2008 | The Singing Machine SINGING MACHINE...
Kareokee singing machine SVt 700
The mikes are easy. Generally the wire gets disconnected - so you can either buy a new wire connector or have it soldered - very easy job. Not sure about the screen display problem - good luck
NJ
Jun 30, 2008 | The Singing Machine Singing Machine SME399...
 Grubhead
Grubhead
