Question about Pyle Car Audio & Video
I need a wiring diagram for a Pyle Model PLCM103 back up camera ... Tried what I thought was a logical approach but cannot get power to the camera..The monitor is good with another source..
blueextc3221
  • 15935 Answers
SOURCE: I need to find out what power sources I can use for my monitor
You need a 10-14VDC power supply. Is this in a car or home?
Posted on Dec 27, 2008
  • 15 Answers
SOURCE: Need a M1Active MKII diagram
Hi, You will need to contact Alesis direct and they will decide whether to email you a copy of the schematics, as they are copyrighted, etc.
Posted on Jun 02, 2009
  • 3 Answers
SOURCE: Need the schematic for a Videoman JCS-701 rear camera monitor so we can wire a new plug for the back of the monitor. Someone cut off the old one.
facing the rear of the monitor, the two round 5 pin plugs on the left are the rear camera plugs on the far right four pin square plug red cable terminal 15 ign power... black cable terminal 31 neg battery... orange cable back-up lights... white cable to hopper lights.., I have a full wiring diagram for the system if you needa copy e-mail me at ssmith01@charter.net
Posted on Jun 12, 2009
  • 14036 Answers
SOURCE: no power to the fuel pump on a 1990 K5
CHECK FUSE + RELAY TO FUEL PUMP.IF THEY CHECK OUT GOOD.YOU HAVE PCM PROBLEMS. MAKE SURE PCM FUSE IS GOOD.YOU CAN BUY A HAYNES REPAIR MANUAL.IT HAS ALL OF YOUR ELECTRICAL DIAGRAMS.
Posted on Nov 11, 2009
caroldon
  • 17130 Answers
SOURCE: Need wire diagram for ccd
You have not mentioned any details of the Make and model of the closed circuit equipments.
Now there is not much to the wiring as the cameras are wired to the monitor through a channel switching mixer unit. This is optional as the camera can be given to the video input of the monitor.
If the mixer is used then the cameras must individually be wired and connected to the number of channels available to the number of cameras that is with you. If the wires are to be carried for a longer distance then a booster video amplifier might be needed.
The output of the video mixer is then connected to the monitor's video input .
The power to the camera can be given externally or from the mixer unit accordingly to the model. If external the voltage can be carried along with the RF cable to power the camera.
Hope you can check on these tips to clear up the connection on the set.
Posted on Jan 14, 2011
My Pyle backup camera says stop all the time I adjusted the eye no luck I cleaned the eye no luck Then I shut off all the power no luck Can you help
if you are talking reversing camera then you are paying attention to the wrong item
the camera just shows you what is there
it is the proximity sensors that tell you to stop or beep when approaching an object
have their operation checked
Dec 02, 2016 | Cameras
How can I get the install instructions for PYLE PL7300BT Rear View camera system?
Pyle PLCM7300BT Mobile Video Navigations Back up Camera Rear View...
Went to this site to find your particular product,it has a downloadable pdf manual whic will by default show you your setup.You may not have the green wire but if you read this manual you may be able to by process of elimination figure out your question.Pyle also has a very good technical support staff,been there done that ,they will also help you out.Good luck hope this helps you.
May 19, 2014 | Pyle PLCM7300BT 7"TFT Mirror Monitor W/...
My pyle 2200 1400 watt 2 channel amp wont get power..... why!!!!!
did you check the remote turn on wire connection at the back of stereo?
Jan 15, 2012 | Pyle Car Audio & Video
Pyle PLCM4300WIR
The Green wire is a reverse trigger wire. It should be tied into the reverse light hot wire. This tells the monitor to turn on and switch to Video 2 so that it displays what is seen by the backup camera. When you take the vehicle out of reverse thus removing power from the green wire, the monitor switches back to normal driving mode. ( no video displayed ).
Looking for wiring from pre amp to amp to speakers
Hello
What is the model number of your Pyle? Without it, how can I post a solution to your problem?. Provide these details to me by Fixya comment box, please.
MERRY X'MAS AND HAPPY 2012 TO YOU ALL
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 24, 2011 | Pyle Car Audio & Video
What to do with the second camera wire? Video connection and...? Pyle PLCM 7200
This is not a solution. I have the same question. In addition, my unit shows blue screen and "no signal". Any guesses?
Jun 24, 2011 | Pyle PLCM7200 Car Monitor
On the PYLE PLCM103 does the red wire get power only when the car is on or at all times. I keep losing my settings when the car is shut off? I have the red wire hot only when car is on.
if u have a yellow wire that should be boobies up to the gin power and red should be constant power or reverse it won't hurt it if u do this
Mar 04, 2011 | Pyle PLCM103 Car Monitor
How to install, since it doesn't come with instructions.
Unless your speakers / boxes are specific for your car, there will not be any installation instructions beyond generalized that may include a wiring diagram, a chart to show how much volume your speaker box needs (minimum and optimum), power handling, etc.
Search for your model / part numbers at Pyle Car Audio and see what information is available there.
Sep 18, 2010 | Pyle Car Audio & Video
Car Audio & Video Logo
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
