Why are both wireless sets indicate line in use? Although phones are not in use.
I can't hear the other people on my plantronics cs 70 which is connected with my cisco ip phone 7941 phone
• Check that all cords and jacks are connected correctly.
• Check that the base has power (red indicator light) and the headset battery is fully charged.
• Try other phone configuration dial settings on the base unit. Ensure the selected number is in line with the position indicator.
• Ensure you are in headset mode. Press the call control button to select correct mode. The talk indicator light on the base is green.
Good luck from Headsets Direct!
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How to hook up cable phone to work fax and answering machine on a cannon Pixma mx340
From the wall your phone cable should go into the fax/printer. Then a phone cable should go from the printer to your phone.
There should be icons next to each jack on the back of the printer which indicates where to connect the cable.
It should work from there, but you might have to go to settings and set up the fax settings such as how many singals should it ring before the fax picks up the line.
Nov 22, 2010 | Canon PIXMA MX340 Wireless Office...
My acer aspire 5810tg says wireless capability disabled and dont know how to turn back on
1. Check out BIOS settings, if there is any option like enable wireless etc.
2. Check "Device Manager" if the wireless drivers are installed and enabled.
3. Try 'Fn+F3 and see if the wifi indication on the right side near power button turns.
4. i dont think there is wireless on/off button. although u may inspect the machine for it.
Nov 01, 2010 | Computers & Internet
Simply can't register any of my 4 handsets with my BT Synergy 4100 cordless phone. All handsets indicate base is "unavailable" there isn't a fault on the line as I have tested it and I have gone over and...
Partial solution. The handsets may be registered to another base.
So go into handset setting, then select base, (select another base if there is one showing).
Then go through the handset registration procedure again.
D
Jun 20, 2009 | Cell Phones
Help I have a Lexmark all in one x7675 which I have been using without problems wirelessly. I am trying to use my home phone number as a fax connected to the printer. It seems to work if I ring it from my...
When you ring it from your biz line, does it pick up? If you're using a high speed dsl line, you'll need to put the machine where a normal phone would go. You should be able to ring the machine using our cell phone. If the machine indicates an incoming call, but still doesn't pick up, check the settings and make sure it isn't set to manual instead of automatic fax pickup.
Apr 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
My LG Chocolate phone is in mute and I cannot get it out of it. Cannot hear any sound out of earpiece...can only use if it is in speaker phone mode...have I changed the setting somehow....is there a way to...
Not sure if this will help you, but when you slide the phone open, do you see 4 red lit-up indicators surrounding your center data wheel? On mine there are:
Red line - top left
Red line - top right
SPK - bottom left
CLR - bottom right
(Note that the indicators stay lit for about 20 seconds)
The indicator at the top left is the MUTE On/Off switch (you will see "MUTE" in the main display, just above the top left indicator). Although there is no real 'switch' there, you just push on that red indicator. It should vibrate when you turn MUTE on or off.
If the indicators go dark, the switch stops working. In that case, you have to slide the LOCK switch (this is a real switch, on the right side of the phone...it's the middle thing - above the MUSIC switch and below the micro SD opening). Just slide downwards and let go...the indicators should light back up, and you can use the MUTE switch then.
Hope this helps.
And BTW, the reason I am answering this question is because despite all I've just explained, my Chocolate MUTE swith, and all those indicator switches, have recently become intermittent. Which means when I am on an important call, after I switch to MUTE I find I can't get it out of MUTE. So if you try the above and it doesn't work, maybe your phone has a problem like mine....
Jul 07, 2008 | Cell Phones
D-Link DI-624
hello!
You cant use a usb cable to configure the router one main reason is that the router do not have a usb port. Since you do not have a ethernet cable, there is another way to configure the router by setting it up wirelessly. You need to have a wireless adapter installed on your computer to communicate with the router wirelessly. Although this is not very advisable because you might experience frequent disconnection everytime you save the settings on the router. i suggest to configure the router using an ethetnet cable instead.
if you are still having trouble configuring your router, call supportrix and use supportcall as your promo code for 1 free technicall support.
Jun 03, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless router and home phone
it is highly unlikely that your router would disable your phone. Although there is a possibility it may cause static on the line.
Feb 03, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless disconnection
Are you located near any other sources of 2.4Ghz interference - cordless phones, baby monitors, microwave oven, like that? I find I have plenty of signal strength but then suffer random drop-outs when my cordless phone is in line-of-sight between the laptop and the wireless hub.
Jan 10, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
