Question about Samsung Televison & Video
I have a Samsung LA32R81BD and for some reason, it won't switch on.
I have tried different power sources, the red light appears, but nothing else. I press any button on the remote and the little red button on the tv just blinks.
    New Friend:
The 3 pins on the phone where the battery connects make sure there all even and straight and has a good connection ..or the power charger is over maybe replace it....... or the input power lead connection is come apart and wont charge
Posted on Dec 25, 2016
  • Samsung Master
  • 6,694 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
SOURCE: Samsung remote control problem
Same issue as lisawrob
Check to see if there is another remote with something sitting on top of it. I had the same problem and found another remote transmitting (continously).
Posted on Aug 10, 2008
  • 1637 Answers
SOURCE: The remote control for my
Remove the batteries then reinsert them. If the problem persists, please change the batteries.
Posted on Jan 08, 2011
  • 358 Answers
SOURCE: My Dish 5.0 IR remote
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Posted on Jun 17, 2011
  • 75017 Answers
SOURCE: My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Posted on Mar 09, 2013
SOURCE: Tv on standby wont turn on either by remote or buttons on tv
I have the same problem on my LG 47LM960v, its only a day old any ideas?
Posted on Mar 30, 2013
Samsung TV won't turn on after lightening storm. Surge protector "sparked once, but all the other things plugged in are operating.
Contact your insurance company and make a claim. Lightning damage to electronics like that is hard to repair.
Aug 07, 2014 | Samsung LN Televison & Video
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
PN50B550T2FXZA won't power up
The continous red light merely means power is getting to your TV. From your description, it is likely the internal power supply has failed
Dec 31, 2012 | Samsung Televison & Video
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
Of 3 lights: green on right and red in center are flashing, unable to stop them.
How to fix blinking lights Printer lights blink in certain patterns to tell you about specific problems. Read this document until you see the pattern that your lights are making. The solution is below each pattern. NOTE: There may be more than one reason why the printer lights are blinking, so you may see several solutions. PRINT CARTRIDGE light RESUME light POWER light Off Off Off c00106861.jpg c00106862.jpg c00106863.jpg Problem
The printer will not turn on.
1. Check the power cord or power module connections at both the printer and the power source (power outlet, power strip or surge protector).
2. Try disconnecting and reconnecting the power cord or power module to the printer.
3. Try reconnecting the power cord or power module to the power source or try a different power source.
4. Verify that the printer is connected to a power outlet that works.
5. Make sure there are no additional switches turned off, such as those on a power strip or surge protector.
6. Check the power breaker to make sure the power source is working.
If these solutions did not fix the problem, have the printer serviced.
Dec 09, 2010 | HP DeskJet 940c InkJet Printer
My 2-wire 2701HG modem has a solid red power light and is not functioning. ATT says it is bad and out of warranty "sorry". Any other reasons for this condition?
RED power light indicates that the modem has gone bad.
Try with a different power cable and power adapter
Try with a different power source
Try to hard reset the router
NOTE: Have all details provided by your ISP before trying this step
If all the above mentioned steps doesn't work please replace it
Jan 27, 2010 | 2wire 2700HG-B Router (2700HGB)
No sound from RS130 headphones
I'm having the same problem with the RS140. Only a few weeks old, and no sound at all coming out (not even the beeps). Have replaced batteries and tried a different audio source. Base station lights are on and indicating it is receiving an audio signal, but nothing is going go the headphones.
Jun 25, 2009 | Sennheiser RS130 Wireless Headset
Dual MXD55 W/6/5 SP CD Problems
make sure the speaker grounds are connected to the speaker ground wires on the deck and not the "chassis" ground. also make sure both power wires are hooked up to a power source. the thinner power wire is supposed to be a switched source (like the ignition key or an accessory switch) that turns the unit on and the thicker one is a constant source which actually powers the deck once the switched source is turned on.
Jul 01, 2007 | Dual MXD55 AM/FM/CD/Weather Receiver
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
