Question about Cell Phones
Flashing behind dial pad and phone won't do amythong
  • kakima Dec 25, 2016
    Hi Debbie Shull, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model phone?
Dial pad not working for keocera e4210
Your dial pad is probably shot, buy a new phone would be cheaper than replacing it.
Aug 19, 2014 | Sprint Cell Phones
Unmute dial pad
The sound of the dial pad can only be adjusted with the silent/mute button on the top left of the phone. If it is switched to silent then the dial pad will make not make sounds, if it is on loud then it will make sounds. There is no other way to adjust the sounds of the dial pad.
Feb 08, 2013 | Apple iPhone 4S
Tryna check my voice mail but my dial pad ain't
Make sure your phone is turned to "Tone Mode". When the call is on press # and then try to use your dial pad. I hope it helps you out :)
Mar 16, 2012 | Samsung Cell Phones
I was cleaning my phone and I pressed on something and now there is music playing that i can not stop,I don't know how to stop the music,my phone is panasonic KX-T7730
Here are two methods to turn off background music, one of these should work depending on which Panasonic phone system your phone is connected to.
1) With phone idle, press the 1 key on the dial pad (turns off background music when it is on and turns on background music when it is off).
2) With phone idle, press intercom button then dial *751 on the dial pad followed by 0 on the dial pad to turn off background music(confirmation tone will be heard) and end by lifting handset and replacing in cradle. To turn background music on, press intercom button then dial *751 on the dial pad followed by 1 or 2 on the dial pad to select the background music source(confirmation tone will be heard) and end by lifting handset and replacing in cradle.
Feb 05, 2011 | Panasonic KX-T7730 Corded Phone
I have an lg tritan and I don't like how my phone vibrates. Is there any way I can change the vibration pattern on my phone?
The vibrate is set by the phone and don't believe they changed But if the can is b in the hidden menu LG Tritan Information Menu a. From the phone dial pad dial b. #help*help (#4357*4357) LG Tritan Feature Menu a. From the phone dial pad dial b. ##Feature (##3328873) LG Tritan Service Menu a. From the phone dial pad dial b. ##LGSERVICEMENU (##5473784236368) c. Service code  000000 LG Tritan Programming Menu a. From the phone dial pad dial b. ##PROGRAM840 (##7764726840) c. Service code  000000
Jan 16, 2011 | LG Cell Phones
Hello, my date is correct but my time is one hour displays as one hour behind. How can i update it? the phone is a Panasonic KX-T7433 Digital super hybrid system
Please follow the steps below to set the time
SETTING THE DATE & TIME:-
With handset down on main phone
Press ‘Program’
Dial ‘**0000’ or ‘**1234’ (system program no)
Dial ‘#000’
Press ‘Next’
Enter the date using the dial pad
Press ‘Next’
Enter the time using the dial pad
Press ’Store’
Press ‘Program
Thanx
Jul 22, 2010 | Panasonic KX-T7433B Corded Phone
Cannot activate dial pad
Do a hard Reboot, Turn your phone off and wait 10 secs then turn it back on it should be fine.
May 03, 2008 | LG Prada KE850 Cellular Phone
How do I set the time and date on the phone and change voice mail
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM 99 on a display phone and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following: Press PROGRAM * * 1234(Default password is 1234. yours may have been changed) Press SP-PHONE 2 Times. To change the year enter the two digit year. If it is correct press FWD/DND to move the flashing indicator. MONTH is changed by pressing the AUTO ANSWER /MUTE key. DAY is entered as 1 or 2 digit day. DAY OF THE WEEK is entered by pressing the AUTO ANSWER/MUTE key. Press STORE to save your changes. Press SP-PHONE Enter 2 digit hour (Hour is flashing). Press FWD/DND button(Minute starts flashing). Enter 2-digit minute(Minute is flashing). Auto Dial/Store Button New time is stored. Lift handset and hang up to leave programming mode
Sep 14, 2007 | Panasonic KX-T7453 Corded Phone
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
