Question about MegaVision Computers & Internet
Having problems with player, we can't access advanced settings anymore or even set up. how can it be reset to factory defaults?
Megavision model MK-852 1TB Password 888888.
sandrew
  • 2961 Answers
SOURCE: Password recovery
download and install this programme, and if you have any passwords set in your pc, click 'Secrets' on the list in the left column and any passwords will appear. http://www.gtopala.com/siw-download.html
Posted on Aug 21, 2007
Fix-4U
  • 293 Answers
SOURCE: how do I reset the factory color settings on my HR crt monitor?
Hi...there,
Well, you need to open your on-screen display on your monitor.
Then look for the factory reset settings and pressed it's will returned to original settings. Happy New Year!
Posted on Jan 01, 2009
  • 223 Answers
SOURCE: How to unlock the memory card..
I dont know if this will work but its worth a try. If you have a cable to connect the phone to your computer and the relevant software then try to copy the contents of the memory card to your computer and then format the card. I hope this works. Good luck.
Posted on Jan 18, 2009
  • 137 Answers
SOURCE: factory set password for samsung x 160
Security Code' refers to a code aimed at preventing others from using the handsets should it be lost or stolen. The initial security code default is '0000'.
Posted on Jul 15, 2009
  • 23 Answers
SOURCE: Resolution won't fit entire screen on the 24.6'' Hannspree HF257
I'm not sure if the setting is the same everywhere but update to latest 9.11 catalyst drivers (im using win7 64bit so if its here its gotta be in everything lol)
1. Open Catalyst Control Center
2. Click Desktop & Displays
3. Near bottom of screen click the down arrow of your monitor (for me it was #1
4. Click Configure
5. goto Scaling Options tab
6. Set scaling options to 0%
This annoyed me for a little while until i realized it had to be driver related because it worked perfectly for a short while but if a game opened up outside of 1920x1080 resolution it wouldn't display properly until a reboot. It fit the screen fine at 1680x1050 because for some reason the scaling was shaving ~15% of the screen displayed for some reason.
Wish you the best of luck :)
Posted on Nov 20, 2009
How to hard reset my philips blue ray
BDP5506, HTS5506, BDP3306, HTS3306, BDP3506, HTS3506, BDP3106, HTS3106
Press the [Home] button on the remote. Then select [Setup]>[Advanced Setup]>[Restore defaults settings]>[Reset Network Setting]>[Yes]
BDP3406
Press the [Home] button on the remote. Then select [Setup]>[Advanced]>[Restore default settings]>[OK]
BDP7320, BDP7520, BDP5320
Press the [Home] button on the remote. The select [Settings]>[Factory Default]>[Network Settings]>[Yes]
http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=BDP5506/F7&hlt=Link_UserManuals&mid=Link_UserManuals&scy=US&slg=AEN
Feb 09, 2016 | Philips Televison & Video
Pioneer dvd recorder dvr 310
Resetting the Recorder to Factory Settings
1. Make sure that the recorder is on
2. Press and hold the STOP button and STANDBY/ON button.
The recorder turns off with all settings reset.
Try this and let me know if it works.
Mar 27, 2008 | Pioneer DVR-3100 DVD DVD Recorder
Factory reset
Use Default Settings If you want to return the initial language setting such as Language, Video, Audio and etc. to the factory default, do the following: 1) Press SETUP button. 2) Press / button to select Misc. 3) Press button to select Use Default Settings, then press ENTER button. 4) Press / button to select "Yes", then press ENTER button. The original setting will be restored. Screen saver : On Do you want to use default setting? Note When you reset the DVD player to the factory default, the DVD player will take 3-5 seconds to reset.
Oct 15, 2014 | Toshiba SDK990 Player
Bios fw140e reset vgn vergine
Follow these steps to access the BIOS on a VAIO computer.
WARNING: Other than resetting the BIOS to the default values, making changes to the BIOS is an advanced procedure that can produce unintended results if not done properly. For instance, if you set a Machine Password and later forget that password, it will require advanced technical support and possibly service to regain access to the computer.
  1. Turn off the computer.IMPORTANT: If you are having difficulty accessing the BIOS, or are doing so as a step in troubleshooting an issue, it is recommended that you remove all media or any peripheral devices connected to the computer before trying to access the BIOS.
  2. Restart the computer.
  3. At the black VAIO logo screen, press the F2 key.
If you are accessing the BIOS as a step in troubleshooting an issue, you may need to reset the BIOS to the default settings. While the exact steps will vary slightly based on the version of the BIOS installed on the computer, these general steps will allow you to reset the BIOS to the factory default values:
  1. In the Setup Utility window, use the arrow key to select Exit.
  2. At the Exit screen, press the down arrow key to select Get Default Values, and then press the Enter key.
  3. At the Get Default Values prompt, use the arrow keys to select Yes, and then press the Enter key.
  4. At the Exit screen, with Exit Setup selected, press the Enter key.
  5. At the Exit prompt, use the arrow keys to select Yes, and then press the Enter key.
  6. The computer will restart.
Reference: How to reset the BIOS to the default settings
Oct 24, 2013 | Sony VAIO VGN-FW140E/W Laptop
How do I reset my Nikon L120 back to factory settings?
When reset are selected, the camera's setting will be restored to their default values.To reset all:menu botton -> setup menu (wrench icon) -> reset ALLhttp://www.nikonusa.com/pdf/manuals/noprint/L120_ENnoprint.pdf (pag.121)
Mar 05, 2012 | Cameras
A friend of mine reset my router and now I can not get my secure setting to work anymore! It wont let me put a password, what do I have to do to reset it and put a new name?
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Jan 13, 2011 | Computers & Internet
HP Laserjet 1320n Admin Password has been forgotten. Need to change the IP address, but cannot access the system. Any suggestions?
joed_calcule
If you changed the password from the default one but forgot the one you set it too all you really can do at this point is set the printer back to the factory defaults. The menu options below will help you do this.
Advanced Printer Settings
Settings tab
Resets = Change all the printer settings back to the factory default settings.
Let me know if you have any more problems or questions
Issken
Feb 17, 2010 | HP LaserJet 1320 Printer
Want it back too factory set up
Go to the on-screen menu.
select 'Feature' (on left)
select 'Advanced Video Set'
select 'Setting' - restores to factory default
If you are having trouble with just the Audio or Video settings and want to reset just one of them back to the factory defaults, there are 'Setting' selections in each of the Video and Audio sections which will set each section back to the factory defaults.
Sep 13, 2009 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Blank Screen
There is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds (some solutions say 20 seconds).
Aug 16, 2007 | Cyberhome CH-DVD 300 DVD Player
Computers & Internet Logo
Top MegaVision Computers & Internet Experts
David Payne
David Payne
Are you a MegaVision Computer and Internet Expert? Answer questions, earn points and help others
