Question about Samsung Refrigerators
The panel light on my Samsung refrigerator model RS25H50000bc lights on panel are blinking up and down what is the problem
SOURCE: power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Posted on Aug 15, 2009
SOURCE: lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Posted on Jun 02, 2010
  • 9 Answers
SOURCE: i got a samsung refrigerator model rs2534ww
Sounds like you just need to do a reset, press and hold the top 2 buttons till it flashes then let go. If you hold it to long it will run a diagnostic mode and may lock up on the blinking light again. The blinking light is a trouble indicator for the service tech. It tells them that sensor or heater is faulty or will point them in the right direction. I found a repair manual on the online auction place E b a y that can help you troubleshoot further but have not bought it as of yet. I just purchased my Samsung and was reading some reviews to see what kind of problems i may run in to.
Posted on Jan 29, 2011
kel1guy2002
  • 3740 Answers
SOURCE: my samsung refrigerator is making a loud humming
The evaporator coils are blocked with ice. This is caused by either having the door partially open or the automatic defrost function has stopped working.
For the moment... unplug the unit, remove freezer contents and direct an external fan into the unit for just over 2 hours. (Water mess) After 2 hours tend to the excess water / tidy up and return the unit to normal service. If the problem repeats in 2 - 3 days you have and automatic defrosting problem and the defrosting system will need to be repaired.
Thanks for choosing FixYa,
Kelly
Posted on Jun 16, 2011
  • 2468 Answers
SOURCE: My side-by-side GE refrigerator, Model
replace the main board located behind the unit behind a silver colored panel at the lower side new board number is a g.e.# wr55x10942
Posted on Aug 07, 2011
RS261MDBP/XAA one blinking light after power outage
on my samsung RS261BPMD, You have to hold the power saver and lighting button down at the same time for 5 seconds to reset
Dec 08, 2013 | Refrigerators
What do the flashing blue lights mean on front of refrigerator?
Flashing blue lights on front of what model Samsung refrigerator?
Jun 12, 2013 | Samsung Refrigerators
BLINKING FREEZER LIGHT
What is the model number of your unit?
Nov 23, 2012 | Samsung 26 Cu. Ft. Side-by-Side...
I got a samsung refrigerator model rs2534ww control panel has a blinkin light. and is not working
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
Power went out briefly. Refrigerator control
Aug 14, 2009 | Samsung Refrigerators
Dash light on monitor no refrigerator temperatures shown on monitor how to reset
Hi there, I have the same problem with my samsung side by side the model no is- RSA 1Wtmh .
The light started blinking after a power cut and the elec came back on and the fridge light just blinks on panel instead of showing temp (the fridge and freezer are working)?
Jul 14, 2009 | Samsung Refrigerators
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Freezer, Ice Maker and Water dispenser not working
it has to get down to the proper temperature after the reset the set point is -4 for the freezer and 38 for the refrigerator. the numbers shown o\n the digital display panel stands for the actual temperatures. When the compartmnet tempertures go down, so do the numbers on thge display panel, and finally they reach the set temperatures. Once the system is stabilized , the display tempoeratures are the set temperature.
Jan 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
