Hello ,sir my PC screen shows error: unknown filesystem. Entering rescue mode... grub rescue> What I do for go back in my laptop?? Please help
    Problem Solver:
  • 12 Answers
Do you have a cd/dvd, thumb drive, or external drive connected?
Posted on Dec 26, 2016
3 Suggested Answers
  • 60 Answers
SOURCE: please help!! i can't open my notebook!!! when i
if you need a quick solution see this ubantu forum discussion
or else do a bit of research
Posted on Aug 05, 2011
  • 180 Answers
SOURCE: PC Boot problem
Try to call experts for good result
Posted on Aug 17, 2016
Upon booting computer, the message:Error:no such partition. Entering rescue mode. Grub rescue.Can you help? Thanks
Your drive most likely failed/corrupted, the computer isn't seeing the original partition you had Windows/your OS installed on. I'd suggest getting a new drive and installing Windows on it, then seeing if you can recover the data off the one that failed from in Windows.
Jan 12, 2018 | The Computers & Internet
Linux System not Booting: A Troubleshooting Session
<span>In a recent days in our lab I've got a with Linux file system. <span> </span>Our lab used Redhat Linux 5.3 Enterprise version. Redhat Linux is an Unix based Operating System and It based on Ext3 file system</span><br /> <span></span> <br /> <span><span>Problem of Linux:<span> The systen cannot access internet. It shows the license expiry error notification. Some</span></span><span>time it doesn't detect the hard drive. Some time the pc can detect hard drive but the Linux started with some errors of file system. Finally the file system of the OS getting crashed and can't boot. At GRUB loading stage it become restarted.</span></span><br /> <span><span></span></span> <br /> <span><span><span>Solution or Troubleshooting: </span><span>If I replace the hard drive cable It detect well and start OS also. Then the pc can detect hard drive but the Linux started with some errors of file system. Then I discovered that there is a problem with OS.<span> </span>Though formatting can solve the problem but that needs a backup of important data. This is time consuming and risky. So I thought to repair the file system</span>.</span></span><br /> <span><span><span></span></span></span> <br /> <span><span><span>At first I'm trying to login in single user mode and repair the file system. I have tried to login by pressing "s" beside kernel at startup in single user mode. But the system doesn't boot. Then I'm trying to repair the OS by RedHat Linux CD. I <span> </span>Insert the CD and select rescue mode by pressing "F5" key. Then I got the single user mode. After that I check all file system sequentially. </span></span></span><span><span><span>/etc /passwd, /etc/shadow, /etc/securetty, /etc/pam.d/login. Those file was wrong. I updated those file by correcting. Then I update the auth config file. After that I boot the system again. But now also it don't get start. Then I rescue the grub by grub-rescue and also update the kernel. After the total process I'm tried again to login from single user mode in root and It get logged. After that I reboot the system and tried to login. Finally it logged in successfully and run properly.<img src="alokerdas.jpg" /></span></span></span>
on Jan 15, 2011 | Computers & Internet
PC Boot problem
Aug 17, 2016 | Computers & Internet
Corrupted os
Have you tried a System Restore/Recovery? Do you have a Recovery Partition? Take a look here:
Apr 29, 2013 | Intel Hasee Nb Q540x-n 13.3" Laptop...
Hello I have a asus 1001p netbook that doesn't
Sounds like a job for a repair shop that can attach an external drive to it and reload the operating system.
May 09, 2012 | ASUS Computers & Internet
Screen stuck at error: no such partition, grub rescue, no recover disk, no installation disc. ubuntu 10.10 disc will not boot.
Sounds like you have serious hard drive errors and may need to initialize your drive to allow the BIOS to see it. When you have done that reinstall Ubuntu and all of your drivers from the Acer web site.
Dec 27, 2010 | Acer Aspire 55345410 Notebook
Pc linux OS reboot loop
It might be cause by The MBR was messed up by a bad grub install. You can try to fix the grub.
If you want to try reinstalling grub, boot from the live CD, log in as root, open a Konsole window, and at the prompt, ([root@localhost ~]#) type;
[root@localhost ~]# grub <Enter>
GNU GRUB version 0.97 (640K lower / 3072K upper memory) <-- This is the output from grub after <Enter>
[ Minimal BASH-like line editing is supported. For the first word, TAB
lists possible command completions. Anywhere else TAB lists the possible
completions of a device/filename. ]
grub> <-- The grub prompt.
From the grub prompt type;
grub> find /boot/grub/stage2 <Enter>
(hd0,11) <-- You'll only have one, use it
grub> root (hd0,5) <Enter> <-- Use what showed up above for yours
Filesystem type is ext2fs, partition type 0x83 <-- Grub reports both ext2 and ext3 as ext2. Don't worry about it.
grub> setup (hd0) <Enter> <-- That is a zero (hd0), not a letter
Checking if "/boot/grub/stage1" exists... yes
Checking if "/boot/grub/stage2" exists... yes
Checking if "/boot/grub/e2fs_stage1_5" exists... yes
Running "embed /boot/grub/e2fs_stage1_5 (hd0)"... 15 sectors are embedded.
Running "install /boot/grub/stage1 (hd0) (hd0)1+15 p (hd0,5)/boot/grub/stage2 /boot/grub/menu.lst"... succeeded
grub> quit <Enter>
Your done; grub is reinstalled
P.S.: If this information was helpful, please rate this solution.
Dec 06, 2008 | fedora Linux Operating System
Computers & Internet Logo
David Payne
David Payne
