When I turn TV on picture keeps flickering and color not right, how can I fix this?
Slinteriors
  • 8617 Answers
SOURCE: 60" Samsung HDTV
Thats a very good possibility. The bearings in the color wheel eventually wear out. Have you noticed any noises lately when the green is messing up.?
Posted on Jan 20, 2008
Slinteriors
  • 8617 Answers
SOURCE: bend in picture and color seperation
try resoldering the convergence ICs if that doesnt help you will no doubt need new Convergence ICs .resolder both of them as thats sounds like a solder issue, unless the IC is getting to the end of its operational ability
Posted on Mar 26, 2008
Slinteriors
  • 8617 Answers
SOURCE: picture
try resoldering the vertical output. Its located on a aluminum heatsink.
Posted on Apr 30, 2008
  • 10 Answers
SOURCE: kp51ws500 color flickering
I'm afraid I don't have good news. This is known as the "Flicker Issue." As a Sony authorized servicer, the shop I worked for was directed to replace all three of the CRT's in the limited number of sets that experienced this issue. The cost per tube is typically around $200. If you decide to take this on, it is best to replace one CRT at a time, power up the set and do the yoke adjustments and electrical alignments to get the new color to line up with the existing ones.
Posted on Jul 06, 2009
SD Tech
  • 14553 Answers
SOURCE: I have a Vivitek RP51HD41-A TV. The TV keeps turning off and on. The color and sound is fine. I have replaced the lamp and this has not fixed the problem.
If its a DLP it may have a color wheel which could be your problem (the colors will change etc)
Color wheels move at high speed and if slow down set will shut down.
The wheel if there will face the lamp. If often if failing will make a high pitched whine or a fan like sound.
Posted on May 30, 2012
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
May 29, 2012 | Vivitek V37655 56" DLP TV
My Smasung projection TV keeps flickering, also every hour or so the screen turns to a green flicker. I have to unplug the power cord and that temporarily fixes the problem. How do I stop the flickering?
The tv colors wheel is dying,replaced the tv colors wheel,will solved this problems.Hire a tv Tech.to change the tv colors wheel,it pretty hard to change the colors wheel in this tv.Because u require take out many machanical parts before u even can come to the tv colors wheel itself to change it.
Nov 08, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I own a pioneer projection monitor model SD-532HD5. It has been flickering on and off where it goes from its crisp color to a hazy type picture. Yesterday, it flickered and the picture went away...
This TV is known for bad solder joints on the Power board. Call a good TV Tech and have him resolder the Power board. It is on the right hand side of the TV looking from the back.
Jul 30, 2009 | Televison & Video
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
Hi
The most likely problem is the auto focus module.
A costly repair.
If you are going to fix it ask for a rebuilt one.
Part# CS00022 R
Feb 29, 2008 | Hitachi 50UX58B 50" Rear Projection...
Screen/Picture Flickering
alo all..
i got problem wif my TV... sony wega trinitron 29inch..
- last 2 night... the TV @ screen slowly lost color for 2-4second... and after that it suddenly turn off for 5-10second and turn back on itself. the led blink 3-5times....
what the problem to my TV?
Jan 09, 2008 | Sony KP-46S25 TV
Sony 20" wega
if your tv give you that color or keeps fliking your tv screen might be crack or even the tv bolbe is burned get it checked out at a tv store
Nov 08, 2007 | Quasar SP-3233 TV
Picture flickers, loses color, goes green, white, and negative, then TV turns off.
the unit has a bad color wheel.rca has seen this problem before.The color wheel has a bad bearing which over time can seize causing the single color you see.Keep on them they know it is defective
Mar 19, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
the last hitachi that had this problem i fixed it bad finding bad solder conenctions throughout the board that the convergance ic's are on, also i foind some on the two main board in my repair. hopefully resoldering the convergance foard will fix the jitter or jumping around problem. if the picture is too red you can also try turning down the screen control slightly. good luck
Jan 02, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
