Question about Hisense Televison & Video
TV keeps going in and out
I have a Hisense TV .Having problem with the picture going in and out.I have the TV connected to a cable box through Media Com.Is there a way to program the TV to read the cable box?
    Master:
  • Hisense Master
  • 708 Answers
Digital audio format, as DTS-HD/Dolby-trueHD/DTS/Dolby-AC3/DSD/HD(HBR), Support signal retiming. Support input up to 15metres AWG26 HDMI standard cable length, output up to 20metres AWG26 cable length. Amazon com MALLCROWN 4 Port 1080p HDMI Splitter with Ac Power adapter...
Posted on Dec 28, 2016
  • Hisense Master
  • 19,664 Answers
Check the connections to the cable box, that they are nice a shiny and clean, and tight. Use HDMI connectors if you can.
Shut the box off overnight. Pull the plug on the television overnight as well.
Connect all back up. If it still does it, you need to disconnect that television and use another to see if the television is faulty, or the cable box / signal is faulty. Then you will know if you need to get the television fixed (Hisense as cheap budget sets) or the cable box, or cabling fixed.
Posted on Dec 25, 2016
I have a hisense tv 32” how do I connect to wireless wifi
This would depend on the model and whether it was a SMART TV.
The internet connection is via a LAN cable or via your satellite or cable box to your Home Network. Your smartphone connect to wifi and via that to the television.
Feb 05, 2018 | Hisense Televison & Video
I have a Hisense 50M700UW TV. It works perfectly except for one problem. When we try to watch netflix through out Fetch TV box the sound comes out as a high frequency unintelligible mess.
You cannot hot swap HDMI connections. First thing to try is to power off and unplug all the devices from everything. Then make the connections to the Fetch and the Television, Then power to the Fetch, then the television, then turn on the Fetch, then the television. There is also a chance that the HDMI cable is an older one and needs to be replaced.
Feb 17, 2017 | Hisense Televison & Video
I have a 50 inch Hisense TV and the picture went out but I'm still receiving sound.... Can you please help me with a fix for the problem?
It all depends what has led up to the problem, however if there has
been no indication of something going wrong,ie. picture getting dimmer, the most common fix is to reset.
First just check all cables are firmly connected. If that does not work then....
Unplug tv, disconnect from cable box, satellite box, any receivers.
Also turn power off to them as well.
Connect everything back and turn on.
Here is a video of other generic problems that can go wrong on any
tv that leads to sound with no picture.
TV Has Sound But No Picture Troubleshooting Guide
Nov 19, 2015 | Hisense Televison & Video
Hisense tv is only show a blue screen no sound just got it at the beginin of the year
I had a Hisense TV in the past, and its a piece of ****. You can call them and talk to them. If it's covered under the warranty, they'll probably email you a label to send it back for repair. But note: they won't send you a box. In most cases, they won't send out a person either. You need to have kept the original box (they say it's stated in the warranty information when you purchase the tv).
Before you call them, can you verify that there isn't anything wrong with the cables (from your tv service provider)? Make sure they're all connected, and that the problem isn't with the cable box.
Sep 30, 2015 | Hisense Televison & Video
New 50" hisense tv .. unable to use hdmi for cable box .. tried different cables and all 3 hdmi outlets on tv ????
There might be a setting on your cable box for audio output. Use the cable remote and look in the audio section of the settings menu and select HDMI output. Mine is under Audio Digital Output in the Audio/Video menu.
Feb 21, 2015 | Hisense 50 Class 1080p LED Smart HDTV -...
SLOW UNFOCUSING AND BLURY PICTURES ON MY HISENSE TV AND LG HOME THEATER
Single speed between new tv and old player may be causing latency. Double check specs on the newest component and make sure they are upward compatible.
Dec 30, 2014 | LG Audio Players & Recorders
Last night my tv worked just fine this morning I go turn the tv on and there's no sound but there is a picture on my 50" Hisense flat screen tv
Check all sources , ie cable box, dvd player or video game. If all have no sound check mute setting in menu or on remote. iI just cable box or sat receiver or evan att uverse box turn them of then back on. the uverse box you may have to remove power. If still no audio request service. The problem is likely the main board or speakers .
Oct 02, 2013 | Televison & Video
Losing sound momentarily
Are you using an HDMI cable and a digital box from your cable/sat company?
HDMI supports 2 different audio formats and when using a box from your provider sometimes the tv thinks the other format is available and switches to if for a few seconds.
Try using a HD component cable, they have Green, Blue, and Red video with Red and White audio, if the issue is your TV switching between formats this should fix it.
Feb 04, 2013 | Hisense Televison & Video
Hitachi Plasma TV _ AV300E
Depending on the way you hook up the media or cable box, this is what you look for, if you are in the video area then look for V1, V2, V3 or the right one if you are on the RF connection then it also has an A and B side. Try each
Feb 27, 2009 | Hitachi 42PD3000 42 in. Plasma Television
Televison & Video Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
