Question about Marantz PMD660 Digital Voice Recorder
Marantz 660 digital recorder
Won't record. Have checked the input and output to make sure that external mic and sp/hp are selected; they are. Still won't record. Not seeing any activity of little green dots when trying to record.
Houston, we have a problem!
  • schmoozy98 Dec 05, 2007
    help I'm tearing my hair out. I can't get record either. It's telling me no track all the time...and yes..before you ask..I am Female..and no I have never used this thing before EVER.
  • BlueTone Dec 05, 2008
    I'm wondering if the ghost power source may have burnt out. I lent mine out and the borrower left the phantom turned on. Now it starts ok and when I hit record, the little green indicator lights don't flash and playback plays white noise.
You might solve your problem by going to this site and uploading the recorder's firmware.
Would like to know if this helps. Good luck.
Posted on Jun 06, 2009
External mic wont work
The A/V out jack is for output from the camera, not input to the camera. The camera has no way to accept sound from another device. You can record onto another device and then combine the soundtracks using video editing software on a computer, or even completely replace the camera's audio track. However this has to be done on a computer, not in the camera.
Jan 15, 2013 | Canon PowerShot SX100 IS Digital Camera
PMD660 Handheld Digital Voice Recorder: I have a Marantz PMD 660 digital audio recorder. T...
This implies that there is not enough current going to the device when running on battery (only back-light but no data) whereas running fine on AC means that the device board is most likely in a good operational condition.
I think maybe once a leaked worn battery which left forgotten inside battery compartment damaged the battery terminals or at least the wires connecting these terminals to the main board, i would recommend you to open and check on that.
Sep 23, 2017 | Marantz PMD660 Digital Voice Recorder
Output mic not working HP Mini
First go to start menu, control panel, sound and audio devices, click the voice tab, and make sure the voice recording has something listed. If not see if you can change it to your MIC. If you get no options in this box you probably don't have the mic installed correctly. If everything appears to be ok in this go to your volume controls, click options, click properties, and make sure you have mic selected in playback sections and check the boxes in recording settings then click ok, one you do this make sure alll volumes are unmuted and turned up.
May 28, 2009 | HP Mini 1000 Netbook
Sonar LE: no playback b/c "NO MIDI OUTPUT" selected
You have to go in to the Sonar configuration and select what the default MIDI and WAV input and output devices are. That is usually handled by the ASIO driver. In your case you would select the USB mic for input, and for output you need to select your sound card. For midi you need to configure the midi controllers and the software synth or soft instrument you are using.
If you need any more detailed help I need to know what version of Sonar LE it is and what sound card. I am guessing it detected the mic and just needs the output device configured as I mentioned.
Dec 31, 2008 | Edirol UA-4FX External Sound System
How do i transfer from tascam DA-30MK11 to computer
From my personal experience, and assuming that you want to do this purely in digital format in order to preserve quality, you need to connect an RCA cable from the digital (SP/DIF) output of the DAT machine to an SP/DIF input of a sound card installed into your computer. Please note that the sound card on your computer must have digital input capability. Also the Digital input (sometimes labeled ‘CD digital’) must be selected in your software as part of the recording controls. To do this, open Volume Control, click ‘Options’, select ‘Properties’ and then select ‘Recording’ (as ‘Playback’ is usually enabled as default), and select the ‘digital’ input. Then using a reasonably good a sound editor or other recording software, start recording keeping in mind that you should configure the software to accept whatever audio data format is used on the DAT tape (i.e. 16 bits, 44.1KHz, or 48 KHz etc) I’m my case the software usually displays a box with these parameters before starting to record. Hope This helps. Good luck!
Nov 03, 2008 | Tascam DA-30MKII
I need more tracks!
Your preamp needs to have 1/4" output jacks which channel all of the mic inputs into these two outs. This isn't typically how a mic preamp is set up however. They often will have 2 ADAT outs which output all the inputs in stereo or some other configuration. You may have one that can do this, but if not you'll probably end up needing some kind of basic external mixer which can handle all of the individual outs from your preamp through the mixer's inputs and then you'd run the main outputs from your mixer into the two inputs on your Tascam DP-01.
Mar 31, 2008 | Tascam DP01 All-In-One Recording Package...
Input audio to PV-GS250 from an external mixer
Problem check list:
- Try another cable in the connection to rule out the cable
- Make sure the 1/8 plug goes in all the way
- Make sure you have it connected to proper outputs on the mixer (and that it's not a powered mixer!)
- Make sure you don't have the output volume up too loud on the mixer
Dec 01, 2007 | Panasonic PV-GS250 Mini DV Digital...
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
input to record from.
• AV1: Audio/Video Input mounted on back
• AV2: Audio/Video Input mounted on front
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Audio Input Problems
buy a creative sound pcmcia card with stereo runs aboout 50 bux at compusa...another solution would be usb audio input, they are also available at compusa,tigefr direct...i hope this helps...
Jul 29, 2007 | HP Compaq nc6220 Notebook
Marantz PMD660 Digital Voice Recorder Logo
397 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
