How do I turn off the pass word every time it goes to sleep
  • Computers & ... Master
  • 18,342 Answers
Click Start, Settings, Accounts, Sign-in Options, Require Sign-in, When PC Wakes from Sleep.
Posted on Dec 25, 2016
Unable to turn off music in sleep mode
Hi, There are different levels of sleep a computer goes through as time passes and it can take a while for your computer to fully awaken. What happens is the computer closes programs not necessary in sleep mode. Some of the small programs used to carry instructions called batch files are in hibernation and especially in older computers with slower processors and very little ram can be a problem. You can set your computer to never sleep by going to the control panel and opening Power Settings. Good Luck
Feb 05, 2014 | Acer Computers & Internet
Printer not responding hp photosmart 6525 after going into sleep mode
My printer will not print after sitting for about 30 minutes. As soon as I turn it off and then back on the job I previously sent, prints out. I tried changing the amount of time before it goes to sleep but this does not correct it and does not seem to be related. You can hit the check mark to wake it up but it still will not print until turned off and then on. Source: How do you turn off the sleep mode in a HP 3600 printer?
This is the only solution is see and it didn't solve the problem
Nov 30, 2013 | Office Equipment & Supplies
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
What is the function of the sleep button on the TruTech TCR1276 Clock Radio. The alarm clock already has a snooze button.
The sleep button sets the radio to play for a set length of time and then turn off. Thus you can fall asleep with the radio on and not have to remember to turn it off. It works when the clock's Auto/On/Off switch is set to Auto or Off. The default is 59 minutes before it turns off. You can adjust the time until it turns off by holding the sleep button and the hour (lengthen the sleep time) or minute (shorten the time until it goes to sleep) button. The longest duration is 1 hour and 59 minutes until shut off.
I hope this helps. You can find the manual for the clock radio at: . Search for the TCR1276.
Jan 08, 2011 | TruTech TCR1276 Clock Radio
Goes into sleep mode will not come back on for 2 weeks or longer
It might be setup to go into sleep mode if it is left idle for a certain period of time. To change the settings click the following(I am assuming you have windows vista or windows 7):
Start,Control Panel,Power options,Choose when the computer goes to sleep(look on the left side),Then adjust the settings to what you wish by clicking the black arrow there.
Also check the "choose when to turn off the screen" in the same spot you clicked Choose when the computer goes to sleep.
Nov 10, 2010 | Dell Inspiron 1525 Notebook
Brother HL-2170W laser printer goes into sleep mode quickly. How can I turn off the sleep mode.
I found this from Tony Benjamin
I have tested it on two different Brother Lasers and it worked.
To cancel DEEP SLEEP on Brother Printer
  1. Go to General Setup then OK
  2. Ecology then OK
  3. SLEEP TIME then OK
  4. While sleep time is display push Down Arrow and CANCEL at the same time!
  5. DEEP SLEEP on/off toggle by Arrow keys
  6. OK to SAVE Deep Sleep off.
It is a shame they don't have this in the web interface or manual they sent with the printer.
Nov 03, 2010 | Brother HL-2170W Laser Printer
My HPw1707 monitor keeps going to sleep and I have to turn off the computer to get the programs to open when I want to work on anything.
Are you saying that the monitor is going to sleep or the computer? If the computer goes to sleep I can understand not being able to get to your programs. This is a simple matter of turning off hybirnate in the power supply icon of your control panel. If the monitor is going to sleep there should be a menu with a timer for sleep time. Just change it to a much longer time or turn it off.
Feb 25, 2010 | HP Computers & Internet
Aspire one with windows XP. Won't turn back on while in sleep mod
I've had spotty luck with Windows and sleep or hibernate modes. I would suggest just disabling sleep/hibernate mode. The options can be found under the control panel under power options. While turning off the sleep mode won't help your battery life, if you ask me, it beats having to power off the laptop by pulling the battery out. If you don't want to turn it off, you can try adjusting the amount of time it lets pass before it goes to slee.
Mar 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
Oct 13, 2008 | E-Machines eMachines Desktop PC
Open Questions:
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
