Question about NetGear RangeMax WPN824 Wireless Kit
I have a netopia 2241N router, when i get on xbox live with my 360 it only let's me play with some of my friends and says I have an open nat
    Master:
    Sergeant:
  • 226 Answers
You will have to login to the router interface and change it nat redirect i think is what you are looking for
Posted on Jul 21, 2009
Every time i try to join my friends game it says session is ureachable and it is really annoying. We live at different IP addresses and could connect before. We all have the same DLCs and it is only me...
make sure you and your friends have open NAT, you need to port forward certain ports for xbox live on your router, try to check if ubisoft also has specific ports need to be open. if still the same contact your ISP, they might be having problems.
Mar 23, 2011 | Ubi Soft Assassins Creed: Brotherhood for...
I play call of duty and my NAT type is strict how can i change it to open?
you need to open the following ports up on your router
Xbox Live 360 requires you to forward the following ports: 53,80,88,1863,3074.
either open the ports for all devices or give your xbox a static ip and open the ports above for it.
Mar 14, 2011 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
How do i change my NAT to open for my xbox 360 so i can play games
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Jan 16, 2011 | Netopia 2247NWG-VGx Wireless Router...
Cant have private chat or play games with friends
This should solve your problem
For most devices that use NAT, port forwarding is not required to connect to Xbox Live. This is especially true if you use an Xbox Live certified device. Sometimes, you may have to configure port settings on a non Xbox Live certified router or gateway.
If there is a firewall device between the Xbox console and the network device, you may have to configure the firewall to enable communication on specific network ports. If the NAT status in the Network Status area of the Dashboard is "moderate" or "strict," you may have to configure port settings.
The following ports must be available for Xbox Live to operate correctly:
� UDP 88
� UDP 3074
� TCP 3074
To open the ports on your router see this handy website here,
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
which gives you a step by step guide.
Before opening the ports you must give your Xbox 360 a static IP address (manual) be sure to use an IP address that no other item on your network is using and is fairly high up in your range, for example if your router's address is 192.168.0.1 then you should use something like 192.168.10 for your Xbox 360.
You can also enable DMZ (Demilitarized Zone) on your router, which will open up all the ports to your Xbox 360, however NEVER use this on a PC's IP, see your router's manual on how to do this.
Once the correct ports are open for your Xbox 360, then your NAT should say open.
Nov 26, 2008 | Microsoft Xbox 360 Console
Router will not allow me to play onling games through xbox 360
If the problem has something to do with NAT firewall in your router, then you may need to open certain application ports for your XBOX in the router. You may check this link from Microsoft http://support.microsoft.com/kb/908874 that talks about NAT firewall and XBOX live.
Hope this helps!
Nov 09, 2008 | Computers & Internet
Opening nat
You just need to enable port forwarding for the ports that the xbox live is using, specifically these ports:
UDP 88
UDP 3074
TCP 3074
You then assign a the static IP you have set on your router, subnet, gateway and dns on your xbox and that should allow your xbox live to work properly with your router.
Aug 21, 2008 | Computers & Internet
N.A.T Settings
So you want the public IP address that your Netopia router is getting to do a 1 to 1 NAT to the private IP address 192.168.1.136? Basically you want to bypass any of the firewall restrictions of the router?
The caveat with this configuration is that if you don't have any other public IP addresses for the actual Netopia router to use then all other devices on your network will now longer be able to access the internet through the router. Only if you have a public IP address that you can assign the router will it be able provide NAT and internet access to the rest of your network.
The 192.168.1.0 network is not routable on the public network. You need your entire network to NAT through your router using a public IP address.
You configuration will work if the Netopia router will allow a 1 to 1 NAT to another node on the network and allow NAT'ing for the rest of your private network concurrently. Of course you need at least (2) public IP addresses in the same subnet as well.
Hope this helps. Let me know if you need better clarification.
MO
May 24, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Xbox live
Router Config>Expert Mode>Advanced>Software Hosting>Games>XBox Live. Make sure you select the device (by IP Address) "Select a User(PC) to Host Games and Services: "
Mar 05, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
NetGear RangeMax WPN824 Wireless Kit Logo
190 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
