How to get gold chain out of drum of Kleenmaid washing machines?
Was able to get half of broken chain out but other half fell through holes in drum
gittos73
  • 244 Answers
SOURCE: door hinges broken and door fell off
yeah very easy and it should only cost at most about £10 undue the old hinge with the 2screws now the door will have two little covers that held the old hinge in place take these out and make sure u get the broken pieces out of them once u have the new 1 put it on the washer and screw down first and then place the covers on the ends of the hinges and put the door in place now redue the screws on the door
Posted on Jun 04, 2008
SOURCE: Kleenmaid top loader Washing Machine Mod KAW 793W leaking
Problem turned out to be a leak from the top, not the bottom and was caused by debris blocking an overflow trap
Posted on Aug 07, 2008
SOURCE: Trouble with Indesit WI 102 washing machine
I had trhe same problem and was going deaf!!! I know this is probably too late for your machine but it may be usefull to someone else with this model.
Originally thought the bearings had gone but had great trouble trying to source some through UK websites so decided to strip the machine. Did this by touch (no manual!) and eventually found that the bolts holding the bottom weight to the drum had all come loose (all 3!). Trying to access them to tighten was the biggest problem as the front of the machine is welded on.
Managed the above by removing the rubber door seal from the door only and tightening two of the bolts from inside the door. The third I managed to access from beneath the machine. All were tightened using 10mm socket on a bar with extension (curtain pole!) slid over the end.
During this process I had the machine on its side, removed the securing brackets, top weight + springs and wedged the drum from beneath and the side as much towards the rear of the machine as possible to aid access.
Good Luck!
Posted on Feb 22, 2009
SOURCE: washing machine
This may be a little late, but it may assist someone else. On my Kleenmaid top loader I found the agitator has clips at the bottom of agitator that clip over a drive hub at the bottom of the "tub" . All you have to do is gently prise it up using your fingers between the bottom of the agitator and the bottom of the tub.
Paul
Posted on Mar 15, 2009
  • 47 Answers
SOURCE: I have a 15 year old Kleenmaid Heavy Duty washing
IT IS TIME TO BUY A NEW WASHING MACHINE. IT MAY COST MORE, BUT TRUST ME, YOU WILL FEEL BETTER KNOWING YOU BOUGHT A NEW WASHER. THE KNOB ON THE OLD ONE THAT IS BROKEN, CAN BE REPLACED, BUT I DON'T KNOW HOW. GOOD LUCK.
RODNEY
Posted on May 14, 2009
I dropped the grit grabber cloth while cleaning the rubber on drum of my LG true balance washing machine and it fell between the inside wall of washing machine and drum. How do I get it out?
A fish hook on a stick. If you put a flashlight into the machine on the drum and shine the light through the holes, you will see the cloth. You may be able to lift the drum a little as there should be some play in it.
Apr 21, 2018 | LG Washing Machines
Kleenmaid dryer
Either needs the drum bearing greasing or needs new bearings
Jun 28, 2014 | Washing Machines
Kleenmaid top loader replace timer
Kleenmaid timers do fail from time to time. Reconditioned timers are a viable remedy and not as expensive as new ones. Depending on where in oz you are, a tech will have to sight the faulty timer to ensure the correct replacement unit. You can't rely on model number alone........Nomess
Apr 07, 2010 | Washing Machines
I have a 15 year old Kleenmaid Heavy Duty washing machine, the wash selection knob has broken, where can i get another in the Newcastle area. Second hand will be fine. Lyn
RODNEY
May 14, 2009 | Washing Machines
Drum noise
Good day.
Maybe there are coins left in the pockets that stucked within the drum during drain process. You can also check the bearing holder of your washing machine for this is also one of the reasons why noises occur during oepration
chris
Mar 11, 2008 | Washing Machines
Drum Paddle broken Hotpoint Aquarius
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
