Question about Video Game Consoles & Games
I have a 2011 2500 I am trying to connect a playstation 3 to the res but it is not reading the connection at all and will not play
SOURCE: sierra aircard 875u connect to Playstation 3
Actually, screw sending me the message. It would probably help more people if I just posted it in the forums.
I have a Verizon Wireless Mobile Broadband card plugged into my laptop because no one in my house has a desktop and we never bothered around with WiFi. I assume this aircard you speak of is similar to mine.
First, connect to the internet with your card. For me there's an application I have to run where I basically just open the app and click Connect. If you have XP (which I really hope you do because I haven't tried this on any other OS) open your Network Connections menu. This can either be done by opening the "Start" menu, highlighting "Connect to" and clicking "Show all connections", or by opening the Control Panel from the Start menu and selecting "Network Connections".
In the Network Connections menu, find your current connection. It'll be the one that says "Connected" in gray letters under the title. I don't know if they all are, but for some reason mine was under the Dial-Up category on the list. Next, on the same menu, look for the "LAN or High-Speed Internet" category. You should have a setting there called "Local Area Connection". I have two. You want the one that doesn't say anything about WWAN or Wireless. It should say something about your ethernet card if you leave the mouse cursor hovering over it.
Now that you've identified both settings, right click the first one you found (the one that says "Connected") and click "Properties". Once that menu opens, click the "Advanced" tab. Check the box under "Internet Connection Sharing" that says "Allow other network users to connect through this computer's internet connection." In the "Home Network Connection" box, type the name of the second connection you found in the previous step (the one that uses your ethernet card). On some computers, instead of allowing you to type anything, that box will drop down and show a list of all your connections. Either way, you know which to pick. Click "OK", and fire up your PS3.
Now, at this point I plugged one end of an ethernet cord in my PS3 and the other into my laptop. Your computer might say something to let you know it has established a Local Area Connection. Log in to any Playstation Network registered profile on your PS3 and open Network Settings under the Settings tab. Go to "Internet Connections Settings". I was able to click "Easy" and my PS3 did all the work from there.
Posted on Aug 13, 2008
  • 8 Answers
SOURCE: connect playstation 3 to speedtouch
Hmm lets see. First try connecting ps3 through eithernet. Since you have not mentioned that, i figure that it works. Do you have a WAP protection on router? Some gadgets dont like to run into the walls sort of speak. Well to try the wireless just go to the network menu on your ps3 and look for your signal in the establish connection tab. See if that works
Posted on Jan 28, 2009
SOURCE: my playstation 3 freezes when i try and play online call of duty
Upgrade to the newest firmware, since 3.0 had some freezing issues with some games, if your internet connection is slow it would also cause it to freeze up
Posted on Dec 24, 2009
SOURCE: trying to connect playstation 3 to my tv having no success
For real try this:
Turn off the tv as well as the ps3 (to where the red ps3 light is on); Then just hold down the power button in the front for like 15 seconds or so, at least until you hear a beep. Then turn the Tv back on, and hopefully once you get the tv back on the correct hdmi input, you'll see that little message offering you to switch to optimum settings.
Hope it works. Did for me.
Posted on Dec 25, 2009
SOURCE: Playstation 3 will not play games or read disc.
I will advice you clean the lens of your ps3 player, cleaning the lens of the ps3 player will make the ps3 player read the disc, if the problem is not solve after cleaning the lens, it means, you will need to replace the lens on your ps3, the lens might be weak that it can no longer read any disc or play any game. the two options above should fix the problem of your ps3.
Take care.
Posted on Aug 01, 2010
I am attempting to connect a PC and/or a Playstation 3 via an HDMI cable and my Samsung Plasma Model HP-5033 will not read the signal between the PC and television. It reads a "No Signal Detected" message...
Adjust the computer resolution to 800-600 and set the lowest bit rate, ie not 32bit. 24bit or 16bit will be fine.
To do this right click on the screen and choose properties, click on settings and you will see the slider bar the resolution and the drop down menu for the bit rate.
The reason you have to do this is because even though its a tv it works on a lower resolution than a computer monitor and is unable to show higher res.
Aug 21, 2010 | Televison & Video
My playstation 3 freezes when i try and play online call of duty
Dec 24, 2009 | Sony Playstation 3 (PS3) Console
Resident Evil 5 PS3 Won't work online
Keep the the ethernet cable connected and install the update. It is required to play online.
May 06, 2009 | Capcom Resident Evil 5 for PlayStation 3
Cant play turismo 5 only on line
All of the new games try to connect to the internet as soon as the game loads. It's like all the silly errors you get when you turn your computer on without the internet. My ps3 automatically connects me to the internet as soon as I turn it on. You shouldn't be limited to playing online like warhawks. I think it's just an annoyance.
Dec 31, 2008 | Sony Gran Turismo 5 for PlayStation 3
Ps3 not playing blue ray
Try downloading the the newest update...or make sure the res isnt too high for the TV i had the same problem but found that the res was on 1080p which was too high...
Nov 16, 2008 | Sony Playstation 3 (PS3) Console
PS3 Won't Play Blu-Ray
If there is no picture on the TV screen: Back to top
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
If the DVD or Blu-ray Disc™ (BD) cannot be played, or the picture is distorted: Back to top
  • When outputting DVD content or PLAYSTATION®3 system format software in SD resolution, only discs recorded in the NTSC standard can be played.
  • If the PLAYSTATION®3 is connected to a VCR or a combination TV/VCR unit, copy protection encoding on some DVDs and BDs may cause image distortion, or may cause the image to become lighter or darker. In such cases, connect the system to the TV directly.
  • If the DVD or BD does not match the region code set in the PLAYSTATION®3, it cannot be played.
  • Some DVDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to temporarily increase the viewer age restriction level.
  • Some BDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to change the parental control level.
  • The BD may be disc-locked. Enter the password that was set when the disc was created.
if non of that works you need to contact Sony at
1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
Good Luck,
Apr 16, 2008 | Sony Playstation 3 (PS3) Console
Won't read game while hooked up to the internet
Take out any USB sticks or Memory stick you have plugged into the machine. Are you trying to use a TIFF exploit? That would do it.
Dec 11, 2007 | Sony Playstation 3 (PS3) Console
PS2 - connection to a HD tv monitor
TV/Video (located on the remote control or flip-down panel) Input button (located on the remote control only!)
Aug 28, 2006 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
26 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
