Question about Sharp LC-60LE640U 60 Inch 1080p 120Hz LED HDTV
Sharp tv model# LC-60Le640u have no power no lights no standby light, 5 volts to main board
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: the power light and OPC light flash but TV won't
try making sure tht tha scart or HDMI cable is securly fitted (depending on which one u using) and this suld solve loss of picture or sound
Posted on Jun 09, 2009
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
  • 8457 Answers
SOURCE: my sharp aquos lc-32p55e tv.When u swith it on it
Ur power board have dead parts,Check parts like Capacitors puff up or burst open.Know how to solder?Or replaced the the whole power board,Websites Shopjimmy.com,Ebay.com have reburbish power board.
Posted on Jan 13, 2010
  • 41 Answers
SOURCE: Shuts off
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Posted on Feb 25, 2010
Tv power supply sharp tv power light come on for a second then shut down is power supplt bad
It's either the main board or power supply.. if there isn't a voltage on the 3 or 5 volt standby the power board is bad if the PSON voltage doesn't change with the off and on button pushed, it should either be low and go high when the power button is pushed or be high and go low..that varies with every set...if you don't get a variance then chances are its the main board .
Oct 21, 2017 | Sharp Televison & Video
My sharp tv model LC-60le640u don't come on just have a white blinking light on the bottom
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jan 12, 2017 | Sharp LC-60LE640U 60 Inch 1080p 120Hz LED...
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp aquos tv, model no. lc-70c-6500u, no audio, visual at power up, standby/power light flashes 2 times long, 5 times short, nothing else happens, what is this mean?
Sounds like main board fault. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 28, 2015 | Sharp Televison & Video
Sharp LC 60LE640U will not turn on power light just blinks
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 08, 2014 | Sharp 60" Aquos LED Smart TV - LC60LE640U
Sharp tv wont turn
If you have power to the standby light but no life beyond that you could be looking at a main tuner pcb: Link attached:
Search results for LC 50LE751K
Jun 06, 2014 | Televison & Video
No power and replaced the power board
What was the problem you ever faced, before replacing the power board? In the main board, there are test points, but normally no repair can be done with these board, other than replacement. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 14, 2013 | Sharp Aquos LC-60LE640U 60" Class LED...
Sharp aquos LC-60LE640U flashing error code 2-5.
Dont buy a Sharp. Buy a Sony, Panasonic, JVC, Visio, ANYTHING but sharp!
Jan 27, 2013 | Sharp LC-60LE640U 60 Inch 1080p 120Hz LED...
Open Questions:
See all Sharp LC-60LE640U 60 Inch 1080p 120Hz LED HDTV Questions
Sharp LC-60LE640U 60 Inch 1080p 120Hz LED HDTV Logo
143 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
