Question about Irons
Why my Boshc iron occasionally works - Irons
Why is water reservoir dispensing steam through the bottom occasionally?
I'm sure its safety issue. Heated water expands into steam, and you wouldn't want it steaming out side or top and burn someone.
Mar 30, 2016 | Irons
Not steaming
Steam Iron Not Working ' ThriftyFun
www.thriftyfun.com/Steam-Iron-Not-Working-1.html
Sep 4, 2013 - Here are questions related to Steam Iron Not Working. ... Why is my mini steam iron not working, after reaching 20 pounds of pressure? How do ...
My iron does not produce any steam - Philips
https://www.philips.co.uk/e/.../iron-does-not-produce-steam.html
PhilipsThe steam control may have been set to zero steam position. 2. There is no water in the tank and/ or the settings are not set correctly. 3. The steam vents of the ...
GC1015/31 Philips Steam iron GC1015 - Philips Support
Nov 18, 2015 | Irons
Mineral buildup in my steamer
To eliminate mineral deposits and prevent corrosion on your steam iron, give it an occasional cleaning by filling the reservoir with undiluted white vinegar. Place the iron in an upright position, switch on the steam setting, and let the vinegar steam through it for 5-10 minutes. Then refill the chamber with clean water and repeat. Finally, give the water chamber a good rinsing with cold, clean water.
-From Reader's Digest 150+ Household Uses for Vinegar
Jul 16, 2012 | Rowenta Irons
Iron was leaking and now stopped working - 2 months old
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Apr 01, 2010 | Sunbeam 4214 Iron
T-fal ultra glide easy cord iron stopped working while ironing
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 03, 2009 | Tefal UltraGlide 1569 Iron
Iron quit working in less than 1 year.
Bought my Shark G1400Z iron about a year ago. The iron caught on fire. Luckly I was only out of the room for a few seconds. What can be done about this?
Apr 05, 2009 | Euro-Pro Shark GI490 Iron
Singer iron
heatman101
Oct 20, 2008 | Singer CSP1 Iron
Irons Logo
69 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
