Question about Amana Heating & Cooling
I have a amana apn12hj,am using it too heat my rv along with the furnace,it shuts off after awhile with a red flashing light to let me know to drain the tank.Why?
  • 85 Answers
SOURCE: my amana 80 sse furnace
Turn off breaker. Turn it back on. If furnace is completely dead still, change your transformer. It's cheap..
Posted on Dec 11, 2008
  • 4 Answers
SOURCE: Fix for coleman rv furnace
Check all limit switches and check power to gas control
Posted on Jan 06, 2009
SOURCE: Amana Furnace runs shuts down then relights
flame rod sensor
Posted on Jan 13, 2009
  • 230 Answers
SOURCE: get heat for awhile then the furnace shuts down.
Great this is good information. I believe it to be one of two issues.
1) The thermocouple (rod that sticks into the flame) is dirty. You can clean this with some steel wool or light sandpaper.
2) If solution #1 does not work then I will say that we have a faulty gas valve (assuming that the gas content and pressure into the house are ok). These are usually pretty generic and can be purchased at your local Grainger (or the like) supply house. Make sure that you are familiar with all of the components involved and read the directions before you remove the old one. If you are not comfortable with this task PLEASE call a licensed technician over. Thanks and good luck!
Posted on Jan 28, 2009
motor1258
  • 6674 Answers
SOURCE: have atwood furnace and coleman mach thermostat
It may be your thermostat, but try this first to see if time delay relay may be sticking. When it won't shut off, turn propane off, and go outside and unscrew the 2 screws that hold your cover on, and lower the cover down. Look straight ahead, attached to the housing of the fan up near top you'll see a square relay (time delay relay) with 4 male spade connectors, and wires attached to each. It's usually held on with 2 Philips screws. Give it a little rap with the handle of a screwdriver or similar a couple of times, and see if fan stops running. While your there as well, pull the wiring connector off the ignition board, and put back on a couple of times, to clean the connections. Now try it again, and let me know what happens.
Posted on Apr 26, 2010
Have amana furnace model GACA070AX30. FURNACE HAS A 5 FLASHES ON ERROR CODE. FURNACE STARTS UP REACHES THERMOSTAT SETTING, BURNERS SHUT OFF BUT FAN MOTOR WILL NOT SHUT OFF. IT ALSO TRIPS ROLLOUT LIMIT
This is a dangerous situation. If your rollout is being tripped open, the heat is going where it should not be going. The fan stays on because it is designed to dissipate the heat.
Nov 03, 2017 | Amana Heating & Cooling
RV Furnace Click
Hello.
First, try to clean the board, perhaps humidity make shortcircuits betwen logic gates. Second check capacitor, if someone is inflated, replace it.
Oct 26, 2014 | Heating & Cooling
RV FURNACE
It's hard to answer your question without the age and brand of your heater but the blinking of the red light can be a heartbeat, which indicates all systems are ok and there is power or the blinking is like 2 blinks, pause, and 2 blinks, pause repeating. That would indicate a failure code. In that case Google the model and serial number to get the failure code.
Amana 80 sv furnace blowing no heat 4 red flashes
Just a guess unless you read from a paper on the inside what 4 flashes mean but usually it's the igniter
Nov 24, 2013 | Amana GMH950453BX Gas Furnace
House cold. furnace runs for about a minute then shuts down and flashes code
What error code? Anyhow, check the following.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 09, 2011 | Heating & Cooling
My amana apn12hj is not blowing out heat? Not sure if i set it up properly?
Dec 30, 2010 | Amana Heating & Cooling
Model G5RA096C-16 motherboard light flashes one time pauses then flashes again and so on. The furnace turns on and blower turns on but does not heat. What does the flashing light mean?
Your furnace is off on a safety limit. Look for small thermal disks around the burner area they will have a usually red switch in the center and 2 wires coming into it. Reset this and watch furnace run. These are called rollout switches and they trip when you have flame rollout. SO WATCH IT RUN. If you have flame rollout you will most likely have a cracked heat exchanger if so you will need a new heat exchanger or new furnace. Next the number of flashes is important on some furnaces it will tell you what part is faulty. Count the flashes then on one of the furnace covers is the wiring diagram it will tell you what the flashes mean otherwise you can tell me and Ill help you out, WHen you reset the power on the furnace does it try to heat tell me what all happens when you shut the switch off then back on. when you turnit back on make sure the stat is calling for heat,
Dec 13, 2010 | Heating & Cooling
Suburban RV Furnace
make sure fan is set auto its just seeing fan motor now
Jul 06, 2017 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
