Question about Garden
I need help on how the belt on my GTX2154 CUB CADET goes on my snow thrower 28 GT. Are there any pictures to refer to?
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a 60
You can download an owners manual which has a pretty clear picture of the routing as well as instructions at this link:
http://lawnandgarden.manualsonline.com/manuals/mfg/cub_cadet/hydrostatic_zeroturn_commercial_riding_mower_48546072_fabricated_deck.html
Hope this is what you need
Posted on Sep 22, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
SOURCE: need to replace a deck belt for a 48" cub cadet mowing deck
Is this any help?
Posted on May 07, 2010
  • 3074 Answers
SOURCE: Cub cadet 42" ltx 1040
http://www.ehow.com/how_6808091_change-cub-cadet_s-drive-belt.html
Posted on May 04, 2011
The chute control cables on my cub cadet 221 snow thrower are stuck, What to do?
flexible wire outer case , bend the case and allow wd-40 to penetrate to the steel wire inside
plastic covered
allow the wd-40 to dun down the wire all the way throufg
replace the cables
Jan 15, 2018 | Cub Cadet Garden
What type of oil do i use
(32 degrees and above, 30w oil) - (32 degrees to 0 degrees, 10w-30) - (32 degrees to -20 degrees below 0 and beyond -20, 5w-20 or 5w-30) Cub Cadets call for a low ash oil. it can be purchased at any cub cadet tractor dealership.
Jan 21, 2016 | Cub Cadet Snow Blowers. 28 in. Two-Stage...
How do I adjust the chute on the cub cadet snow blower it only goes partway to one side and all the way on the other side
Un plug the chute control rod..put the chute in middle (foward) and the handle at 1 oclock and remount the chute rod..see at 3:40 on this video ===>
Feb 15, 2015 | Cub Cadet Snow Blowers. 26 in. Two-Stage...
HOW TO O REPLACE A AUGER BELT ON CUB CADET SNOW THROWER BELT PART #954-04195A
Just generalizing. Take off the plastic cover between engine and Shoot. Most auger belts will not fit down between the Pulleys unless you loosen the bolts that hold the entire front assembly on. Once they are lose you can get the belt down there to get it around the large Pulley.
Feb 06, 2015 | Garden
I have 2005 Cub Cadet 528 SWE snow thrower and have trhe following problem. last week when clearing snow I ran over a wooden hockey stick and had to dislodge the broken pieces. Since then the thrower has...
http://www.manualslib.com/manual/34068/Cub-Cadet-Swe-528.html?page=20#manual
Check this page,
Two stage snow blowers all tend to have sheer pins
I would suspect that the holes seen in the picture are for the sheer pin, check with club cadet, figure same as auger pins, if so feel for the hole with your finger then inser a short nail till you feel a rough spot then tap with a hammer till it comes out, otherwise you have to take the mess apart completely.
Jan 02, 2013 | Garden
Cub Cadet tractor choke problem
There is a web site called mytractorforum.com which has a subcategory especially for the cub cadet. I recommend referring the problem to that site.
Jan 26, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
