Question about Electrolux Ovens
Fault F239 Electrolux Oven EVEP6155A Help please
  • 490 Answers
This is an error for the touch controls its often caused by moisture getting into it, there is a strip of foam you fit under the touch panel to prevent it happening, it can be ordered from electroloux
Posted on Feb 06, 2017
I have an Electrolux Oven EVEP6155A. I have a fault Code F239 showing on the screen Can you please help
this is a error for the touch controls its normally caused by moisture getting on it, theres an upgraded part you can order from electrolux which is basically just a strip of foam you fit under the touch controls to prevent moisture getting in
Dec 24, 2016 | Electrolux Ovens
Top part of oven not heating up
Thank you for your post, friend!
Based off what you have described your Electrolux double wall oven is not heating up inside the top portion. It could be a miscommunication within your oven and you can usually perform a reset to clear that out. In order to reset your oven you would need to flip the household circuit breaker off for roughly ten minutes. If you restore power and continue you having an issue with your oven I would suggest you could have a possible fault with the control panel, thermostat, element, or connectors. Typically, this is not a simple DIY job. You may need to look for assistance with replacing any electrical components and I would highly suggest having a professional technician help with that. Hope this is helpful. -Matt
Feb 23, 2015 | Electrolux 30" Built-In Double Electric...
How do I fit a seal to an Electrolux oven with rounded corners and no clips
Good Afternoon friend, thank you for your post!
I understand that you need help with the seal on your Electrolux oven. Could you provide me with your model number, please? The serial tag is located on inside wall of your oven. With that information I can provide you further assistance. -Matt
Feb 12, 2015 | Electrolux Ovens
Electrolux EOD5310 Electric Double Oven power to oven but no heat
If you have a problem with your Electrolux EOD5310 cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jul 06, 2014 | Electrolux EOD5310 Electric Double Oven
I have an electrolux oven eocl633w. The grill works with the top element but when you select oven, the lights go on, the fan goes but no heat from either element. We thought it might be the automatic timer...
It definitely sounds like the muli-function selector switch. It is probably best to contact the spare parts section of electrolux or the company which owns electrolux and quote the oven model number. You can't always get exactly the same switches as they sometimes discontinue the original.
Feb 14, 2011 | Electrolux Ovens
Electrolux oven eog7330xn stopped working
Hi Chaps,
I have an 18 month old Electrolux Gas oven model No: EOG7330XN which worked for 14 days then died. There was no power displaying and I called Electrolux to service within the warranty period. The engineer removed the front control panel and replaced a fuse inside which brought it back to life.
Am I right this is possible, I have removed the panel but can't see any fuses?
Jul 30, 2009 | Electrolux Ovens
which stat is it - overheat stat or temperature stat?
May 13, 2008 | Electrolux EOB6636X Ultrafan Electric...
Gas oven - fan constantly on
assume this is the casing fan. this is controlled by a fan stat which may be faulty. however, this fault should be covered under guarantee so call service agent
Apr 23, 2007 | Electrolux EOG6330 Gas Single Oven
Ovens Logo
498 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
