Question about Electrolux Ovens
I have an Electrolux Oven EVEP6155A. I have a fault Code F239 showing on the screen Can you please help
  • 490 Answers
This is a error for the touch controls its normally caused by moisture getting on it, theres an upgraded part you can order from electrolux which is basically just a strip of foam you fit under the touch controls to prevent moisture getting in
Posted on Feb 06, 2017
2 Suggested Answers
  • 5189 Answers
SOURCE: fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
Posted on Sep 08, 2012
Fault F239 Electrolux Oven EVEP6155A Help please
this is an error for the touch controls its often caused by moisture getting into it, there is a strip of foam you fit under the touch panel to prevent it happening, it can be ordered from electroloux
Dec 24, 2016 | Electrolux Ovens
I have oven electrolux MODL. .EW30IS65JSA ..its has problem error .E35 how I can salve this ??
Hello Awad, thanks for your inquiry!
From what you have described your Electrolux range is displaying an error code of E35. I am not showing that as a valid error code, maybe a digit or the panel is misreading. I would suggest performing a reset on your range to see if that would help clear any faulty codes. You can reset the range by disconnecting the power cord for at least ten minutes. If you continue to experience an issue with your range I would recommend seeking additional assistance from a professional technician. I hope this information is helpful to you. -Matt
May 05, 2016 | Electrolux Ovens
Electrolux oven error code f130.what to do?
Hey Luciano, I appreciate your inquiry!
From the information you have provided your Electrolux oven is displaying an error code of F130. I have researched possible error codes and it appears that this error code is invalid. I would recommend performing a reset on your oven and you can do that by unplugging the power cord for roughly ten minutes. If you restore power and continue to receive the error code can you please comment? I would be happy to assist you further. -Matt
Nov 29, 2015 | Electrolux Ovens
Getting f 68 fault code electrolux oven
Hey karl miller, I appreciate your inquiry!
From the information you have provided Frigidaire dryer is showing a "E68" error code. "E68" usually indicates that one of the keys (buttons) is stuck closed (active). You may enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing. This is not a simple DIY job. If you need additional assistance I would recommend contacting a professional technician for proper repair or replacement of electronic components. Hope this helps! -Matt
Feb 13, 2015 | Electrolux Ovens
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
Electrolux EOD5310 Electric Double Oven power to oven but no heat
If you have a problem with your Electrolux EOD5310 cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jul 06, 2014 | Electrolux EOD5310 Electric Double Oven
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
I have an AEG Electrolux oven D8800-4 double oven and have ann error code A3, what does this mean?
I hope you mean error code F3. if so then that means a software error and if you disconnect from mains supply then reconnect this should reset the fault if that does not work you may have a damaged circuit board.
Hope I helped.
May 06, 2010 | Electrolux Ovens
Oven tempeture lower than setting by 100 degrees on 350. even after pre-heat cycle. slightly more accurate at higher temps. i have a regular oven thermometer to check it. it was working well until...
Hey-  Let's fix this thing.  Several things can affect indicated/actual temperature.  The temp probe should test ok across it's lead wires at around 1100ohms. The computer usually shows a fault if the circuit is open, but won't show a code if it hasn't failed completely.  The next suspect is the igniter for the oven burner.  These can become weak with age, affecting gas flow to burner. Testing igniter is not really possible when it comes on and the part is usually replaced.  The regulator is next in line, occasionally causing variable flow to burner.  As you can see, quite a bit to consider.  On site diagnostics is usually required, but this gives you a start.  Installation instructions are available for all parts.     Please acknowledge this post if my info and time spent helps you.  Have more info if needed.  Thanks- Ed
Mar 26, 2010 | Electrolux Ovens
Oven not working
is this a gas oven or electric?
Oct 24, 2006 | Electrolux EOD5310 Electric Double Oven
Ovens Logo
442 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
