Question about Sharp XE-A507 Cash Register with Hand Scanner - Cash Registers &
I cant hit any button and it has stuck with off mode.what should i do? i tried everything but when i hit 1 and clerk sign on. it says unidentified. i have xe a507 cash register.
flexion1
  • 737 Answers
SOURCE: Sharp cash register XE-A41s
Hi. turn key to OPX/Z mode. Press the receipt button. Turn back to REG mode. Now when you want to issue a receipt, press the receipt button.
Mark
Posted on Jun 23, 2008
SharpCSR
  • 11 Answers
SOURCE: sharp xe a201 has an e.3.2 error,
Hello, my name is Curtis, and I am a Sharp Customer Service Rep. What you are going to want to do first is press the CL on the grey keys, then the ESC in the bottom left corner twice, (CL ESC ESC.) Then on the grey keys type in the clerk number (01) and press that blue, CLK# key above the department keys, the screen should read -01- from there you should be able to press the CA/AT/NS key and the drawer will open and you will be ready to go. However if there is any problems doing this please contact our support line at 1-800-237-4277, we are open every day of the year till 7:00 PM central time. Hope this works for you!
Posted on Jun 30, 2009
  • 130 Answers
SOURCE: I have a Sharp XE-A41S cash register. I cannot get
call the company for help
Posted on Jul 18, 2009
SOURCE: Software for Sharp XE-A201 Cash Register
I HAVE the software disc and computer cable for the XE-A201...anyone need it?
Posted on Jun 17, 2011
Electroboy
  • 1780 Answers
SOURCE: E 32 CODE ON A XE-A206 CASH REGISTER
E32 means no one has signed on to use the machine.Try 1 then CLK# button.
If anyone needs a manual, C-tech have the Sharp XE-A206 user and programming manual here:http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A206_operation_manual.html
Posted on Nov 03, 2011
Casio SE c2000 changed all prices - everything fine then decided to update clerks & nos - disaster! Locked out of machine now can't sign in so can't do anything??
1. Try logging on as a clerk above the ones you programmed e.g clerk 9 might have original sign on code if you didn't go that high.
2. Try to reprogram the numbers in Program mode (some registers let you in if you are in PGM mode).
3. take it to a dealer and they can read the clerk codes to see what you programmed and change them for you.
4. Initialize the whole machine and lose all programming (you might have a painful amount of work to program it again so this is a last resort).
May 13, 2018 | Retail Supplies
I can't sign in under my clerk ID!
Have you tried every other id? If so, you could try a flag clear (see the manual for procedure) which usually loads a clerk in order to allow programming while in program mode. Then you can edit clerk file again. Good luck
Apr 16, 2016 | Casio PCR-T470 Cash Register
How do i get rid of register mode closed?
You need to sign the clerk on. In REG, try pressing 1 then press the clerk button.
Apr 04, 2014 | Samsung Sam4s ER-5200M Cash Register WITH...
All buttons of my cash register are disable except rcpt feed
this is usually the result of having no clerk signed in. turn the key to op mode and press 1 then hit sign in button
Jan 07, 2014 | Sharp XE-A23S Cash Register
This register appears to be ''closed''. Every mode states to be closed
closed means there is no clerk signed in. if either pressing the clerk button at the top right of keyboard or pressing 1 clerk does not sign in a clerk it has probably lost it's programming. to reset to factory condition turn the C key to six oclock position and unplug then reconnect plug while holding down the double zero button
Jan 03, 2014 | Sam4s SAM5215 Er-5215M 1
TK-1550. I try to enter in my program or regular mode, but I can't : E008. I think I made a mistake when I had program clerk options. Can you help me ?
Hi. Error 8 usually means no clerk logged in. Type your clerk code and press your CLK# (clerk number) button to sign on. Default is 1 then CLK#
Jan 19, 2011 | Casio Parts Cash Register PC Desktop
How to set up 4 clerks on the key board of casio tk2700 cash register to be used as multi user
The 2700 has to be set to sign on clerks straight after a RAM clear if you want this feature, otherwise you use the buttons next to the mode key to change clerk. Try the buttons first to see if they are changing clerks. If not, then you can have sign ons. If they are, you are stuck with this unless you clear the whole machine and start again
Dec 16, 2010 | Casio Parts Cash Register PC Desktop
Casio TE 8000f i have accidently deleted my Sign on button, and now i cant sign is as manager or programmer, is there a way around this?
If you flag clear it (no loss of data) then most models will give you a temporary clerk in order to program with. While you are in program mode, set a clerk button before you return to REG mode. Consult your manual for flag clear instructions as this model works differently for flag clearing. If you need a manual, c-tech collective has one here: http://the-checkout-tech.com/manuals/TOC/cashregisters/Casio/TE-7000S%20and%20TE-8000F%20and%20TE-8500F%20programming.TOC.pdf
Sep 03, 2010 | Casio Parts Cash Register PC Desktop
The clerk number is stuck on 3 after clearing out an err mode
I think you have a clerk stock in memory . move to pgm mode 3 subtotoal o and hit clerk key then subtotal.
Mar 24, 2009 | Casio Parts Cash Register PC Desktop
Sharp XE-A507 Cash Register with Hand Scanner - Cash Registers & Logo
Top Sharp Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
