Question about Food Mixers
Mixer will not power on it has not been running I just pulled it from the shelf to use
Kitchenaid Hobart K45SS when set at 1-2 accelerates to high speed when making dough. How can I fix this?
Usually when the mixer runs only on high speed it is caused by the control plate adjusted incorrectly or the control plate spring unhooked. Remove the trim & end cover on the mixer and check the control plate spring, if unhooked, attach to bottom of the control plate and squeeze the spring end, also check the speed control plate screws,there are 3 screws on this plate, one at the bottom two at the top, see if adjusting the top screws slows your mixer down.
Next check the wiring of the mixer, Insure everything is wired correctly, to get wiring diagram go to the last page of the service manual. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
If neither of those fixes the problem it is probably a bad phase control board, or a shorted phase control board. With the line cord disconnected, pull the t-bar contacts to open and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run, if it operates at full speed the phase control is defective and needs to be replaced.
Use the service manual to aid you in taking apart the mixer, trouble shooting the problem and putting the mixer back together, based on the mixer only running at high speed some of the time I would assume it is the speed control phase board.
If you have any questions let me know.
Thank you,
Colleen
Customer Service
MendingShed.com
Apr 24, 2013 | KitchenAid Food Mixers
Mixer only runs at one speed
if it runs only at high speed it needs a new phase control board if the mixer is post 1978, if the mixer is pre 1978 then you will have to replace a capacitor on the end of the power cord inside the mixer. if the mixer only works on one speed that is not high speed then you need to adjust or replace the speed control plate on post 1978 mixers and the capacitor on pre 1978 machines. Hope that helps
Jan 30, 2013 | KitchenAid Food Mixers
My kitchenaid mixer run on high at all times
If your mixer only runs on high speed there are 3 things that can cause that. The first thing to check will be the speed control plate, Remove the trim and end cover on the mixer, the first thing you should see is the speed control plate, this has 3 screws on it, try adjusting the top two screws 1/4 turn, this should slow the mixer down, do not over tighten. Also check to see if the control plate spring is unhooked. If the spring is unhooked, attach to bottom of the control plate, and squeeze the spring end.
If this does not fix your mixer, check the wiring of the mixer, you can locate a wiring diagram on the last page of the service manual.
If the speed control plate is adjusted correctly and all the wiring is correct it will be your speed control phase board. You can test the speed control phase board to see if it is shorted. With the line cord disconnected, pull the t-b ar contacts to open, and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, teh phase control board is defective and needs to be replaced.
This will aid you in taking the mixer apart, troubleshooting and putting it back together, remember the wiring diagram is the very last page.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 07, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
I just replaced worm wheel on my KitchenAid Stand Mixer. Power was working prior to worm wheel breakage. Mixer was running, but not spinning. Dismantled Mixer, and replaced worm wheel. Put back...
Check the carbon brushes, look inside the hole, it is keyed, the brushes only go in properly one way. Match the missing corner on the brush to the blocker inside the brush holder.
Sep 07, 2017 | KitchenAid Food Mixers
Only have two phase power power company refuses to install three phase can i run my hobart h600-t mixer serial#31-1068-582 ml# 104385 with just two phase?
first thing, there is no 2 phase pwr. there are only single phase or three phase.you have 2 choices either you can convert mixer from 3phase to 1phase which will be expensive, or you can get a rotophase which will make 1phase pwr to 3phase pwr to run mixer, dont go with static phase inverter, only the rotophase inverter
Jan 19, 2010 | Hobart H600 Stand Mixer
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Dec 20, 2009 | Hobart H600 Stand Mixer
Kitchen aid mixer
take off the chrome ring around the rotator. remove the screws that were hiding under it. pull off the rotator and replace the "O" ring on the shaft.
Mar 08, 2009 | KitchenAid K45SS Classic Stand Mixer
Hobart d-300 mixer
To Whom it May Concer: At the school I work we have a Hobart D-300 Mixer. When we mix bread dough it pulls alot of current and trips the breaker. The max current draw on the name plate is 10.1 amps. I have seen the current go over 30 amps during the mixing process. Under no load the mixer pulls 7.8 amps. I dont have any information about this machine on paper and I can only go so far with troubleshooting.
My questions to you are: Is it normal for the mixer to draw 7.8 amps under no load? And is their a manual online I can look at so I can check the oil levels and make sure I do not have a low oil/needs greasing condition.
Thanks for your help and time,
Kenneth Clayton
Spartanburg Schools Dist#2
Apr 16, 2008 | Hobart D300 Stand Mixer
Food Mixers Logo
91 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
