Question about Water Heaters
What makes breaker on heater to keep going out
    Top Expert:
  • Water Heaters Master
  • 50,533 Answers
Dead short or earth leakage from failing insulation
call an electrician to check out the reason and fix
Posted on Dec 24, 2016
My Rinnai tankless water heater keeps tripping the breaker then when turned back on, it begins to beep and displays a code 12. What is causing this? It is new and this is the first time any code came.
Go to Rinnai and get a manual with the error codes... for example a shorted element will trip breaker... wiring problems can cause breaker to trip... anything that causes heat on wire to exceed amp rating of breaker will cause it to trip...
http://waterheatertimer.org/Water-heater-is-tripping-breaker.html
Sep 12, 2017 | Rinnai Water Heaters
1999 Artesian hot tub heater keeps tripping electric breaker
read the pump motor tag. it should have wattage consumption. if u have already been running it, ensure breaker is pushed all the way in. and u don't have a new appliance running on the same breaker.make sure the grounds are clean and tight.thats all I can think of. if persists,use a multi meter and start testing.
Jan 02, 2015 | Water Heaters
Rheem gas power vent water heater model# 21vp75e-19 keeps tripping gif breaker when plugged in, help please
Check where wires go into housing, look for a bare or nicked neutral (white) wire. GFCI's only trip when the neutral makes contact with ground.
Mar 08, 2014 | Rheem Water Heaters
Hatco booster blowing breakers
Copy following link:
http://waterheatertimer.org/Water-heater-is-blowing-breaker.html
Hatco booster heater typically has 2 sets of thermostats and elements located on each end of heater.
Both sides might be controlled by same 60 amp breaker, or the heater might be controlled by two separate 30 amp breakers.
Be sure you have correct wire and breaker.
After reading steps on link above, add comment and say if this is new installation, or older installation that suddenly started throwing breaker.
Apr 08, 2013 | Hatco 208/3 C-12 Compact Booster Water...
The bottom heating element keeps blowing breaker and bottom of heater is filling up with water around heating element
If there is enough water around element and lower thermostat, it's going to blow the breaker. If you don't have leaks at the pipes above, it's probably time to replace the heater. If the leak can be found and repaired, there may be hope for the heater but, if it is leaking past thermostat, you probably have a crack in the threads. Make sure, if your going to work with the wiring of the unit, that it is turned off and, if it is on, make sure you're careful and not standing in water. You could quite possibly have a cracke or broken tank.
Jun 25, 2011 | Rheem Water Heaters
After installing my titan N100 the breaker keeps tripping went from 50 amp breaker to 60 and still keeps tripping how do Isolve this problem?
You had an instant heater there before? Or a different type? Your breaker numbers don't mean anything to me, I need amps and volts, what is the amp? 30? and the volt is 220? Or are you in Europe?. And you had the four wires in there before? And you have all 4 wires on the heater line? And the heater is grounded? It should work. Unless it is not getting enough juice, but you already upped the amp. Let me know what you got.
Jul 03, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
The black wire in the hot water heater is glowing red, I can hear a noise in the breaker bos so I pulled the breaker loos and the plastic to the panel has been melted.
Breaker may be defective and not clipping off when it overheats. More and more power keeps going through it and nothing to stop it. Or check the wiring on the heater itself to be sure they are connected right.
Jan 27, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
THE INSTA HOT HEATER KEEPS TRIPPING THE BREAKER?
Hire an electrician.  The breaker needs to be replaced or the wiring in your house is not able to handle it.  I believe most need 2-30amp breakers.
Mar 03, 2009 | Emerson Insinkerator 2.5 Gallon Water...
Water Heaters Logo
37 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
