Question about Proscan Televison & Video
I have a Proscan pledv2488a. There is a disk in the DVD player, but I cannot find a way to eject it. There appears to be no eject button on the remote. What can be done?
  • Proscan Master
  • 5,387 Answers
Do you have the original remote or a universal remote? On the original remote, the Eject button is also the Favorites (FAV) button. It's just below the Volume - section of the Volume toggle on the left side of the remote. The button has an upwards arrow above a line on it. You probably need to set the source to DVD for the Eject button to work properly. (If the source is TV, the button will add or delete the current channel to the Favorites list.) You can cycle through the input source options by pressing the Source button on the TV or the remote. On the TV, the Source button is between the Power and Menu buttons. On the remote, the Source button is on the right hand side above the Up arrow key.
The manual for the PLEDV2488A is available from Proscan at the manufacturer's site: http://www.proscanvideo.com/product/PLEDV2488A . Click on the Downloads tab. The direct link is http://legacy.curtisint.com/html/CustService/Manuals/PRO_PLEDV2488A_EN.pdf . Page 8 describes the remote buttons.
I hope this helps.
Posted on Dec 24, 2016
  • Howard R Pletcher
    Howard R Pletcher Dec 24, 2016
    That did it, thank you. I have the manual, but couldn't find the eject in the fine print and didn't recognize the symbol.
  • Cindy Wells Dec 24, 2016
    You're welcome. I sympathize with the small print problem. Cindy Wells
Disc will not eject from dvd player
Have you tried both the eject button on the DVD drive and the remote? Is there a disk jammed in the drive? Here is the manual:
http://www.curtisint.com/html/custservice/manuals/PRO_PLEDV1945A_EN.PDF
most of the time there is a small hole near the eject button that you can unbend a paper clip and insert it into that will release the door.
here's a video.. it's a computer, but same principle:
Open Stuck Drive on Your PC
Aug 14, 2015 | Curtis ProScan PLEDV1945A 19"" TV/DVD...
How do you eject the DVD
I you can't do it with the Remote control, you might be able to do it on the TV itself.
I'm not positive about this, but there should be a button on the back outer-edge of the TV that may control the DVD player.
If not, here is a link to Download the manual. Scroll down & click on 'Guides + Info' and then the download link.
http://www.us-appliance.com/pledv1945a.html
PLEDV1945A Proscan 19 LED 720p HDTV with Built in DVD Player
Good luck.
Andrew
Feb 24, 2015 | Proscan 19 In. 720p LED HDTV/DVD Combo...
Looking for the AT&T uverse remote control Proscan 24" LCD combo TV/DVD
If you wish to know its programming procedure, check the sites linked here. it is difficult to type all all here by this wondow. http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 08, 2014 | Proscan 26LB30QD 26 in. LCD HDTV
How do i unlock the region on my samsung bd-e5400 region free?
1. Ensure that there is no disk in the tray.
2. Switch the player off and then back on. This is necessary to clean-boot the
firmware.
3. Wait until the main menu page appears and the player stops doing
anything.
4. Press the eject button to open the tray. (The button is between the "Power"
and "TV Power" buttons at the top of the controller.)
5. Press the eject button to close the tray.
6. Wait while the player searches for a disk.
7. As soon as the "No Disk" message appears at the top left corner do the
following.
8. Press the REPEAT button - just above the TV channel selector at the bottom
right of the controller.
9. Enter 76884 on the number pad.
10. The region code "4" should appear at the top left corner of the
screen.(this just flashed on then off, so keep an eye on the screen)
11. Enter a "9" to make the player region free.
12. Power down and power up again.
13. Play a foreign DVD to verify the change.
Mar 22, 2013 | Samsung BD-E5400 - Blu-ray disc player
How do u eject DVD on proscan pled 2488a? Tv with built in DVD player
tried to unplugged and re plugged the unit and push eject button. if can not get with reset at this time you are going to remove the cover then access the internal part of the dvd player. check for an stuck up in the cd tray mechanical assembly.
Sep 27, 2012 | Televison & Video
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Dvd stuck in tv dvd player
According the owners manual you will have to call PROSCAN customer support for help with this problem. The telephone number for customer support is 1-888-977-6722. You can also go to The website and use the customer support there. The website for PROSCAN is www.oncorpus.com. I hope this has helped you with your problem.
Mar 12, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Televison & Video Logo
150 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
