Question about AMP Music
Guitar amp won't turn on. It's a mustang II. I just plugged it in, and nothing. was wiggling the cable and the "on" LED flickered, then went out. I've tried wiggling the power cable, swapped outlet
    Top Expert:
  • AMP Master
  • 3,082 Answers
Try using a completely different power cable to rule out the problem.
Posted on Dec 27, 2016
  • 1137 Answers
SOURCE: Unit inoperative, one LED blip on battery install only.
Its possible that if you changed strings the saddle might have changed position in its slot. It has to sit uniformly on top of the piezo element in order to work properly. Try testing the pickup(piezo element) first before suspecting the preamp.
Posted on May 23, 2009
  • 5603 Answers
SOURCE: my spider III 15 watt buzzes whenever i have a cable plugged in.
MAKE sure you have it connected to a three wire circuit that has the ground. A lot of these style amps will buzz if they are left ungrounded.
Also search for sources of buzzing light light dimmers.
Further, power supply electrolytic filter caps are suspect.
Posted on Aug 27, 2009
  • 5603 Answers
SOURCE: my guitar won,t play threw the amp lots oof static
The things to check arre FIRST the cable. These often have breaks or bad connectors. Replace with known good one and try it.
Next are the jacks on the guitar and the amp. These go bad and wiggling the KNOWN good cable at each end will flag which or both being bad.
Next are the switches and potentiometers in the guitar. Use some CRC226 sprayed into the pot and switch contacts... use sparingly...
The key is to find which thing or things are bad.
Posted on Sep 15, 2009
  • 1126 Answers
SOURCE: Crate Bass Amp B100 - No sound.
Do you happen to have another speaker that you could hook up to speaker output? This would bypass the amps internal speaker and lf you get sound from that setup, it would mean either a jack failure or possible internal speaker problems. Please let me know.
Posted on Jan 24, 2010
  • 417 Answers
SOURCE: My MT-2 wont distort my guitar.
A few things to try....
Usually the adapter will over ride the battery when used.
1) Make sure your 1/4" cables are working properly without the pedal "in-line".
2) Take out battery, and use just the adapter only. Make sure it is the correct and proper adapter that works with Boss. Usually the PSA-120. If you are not using a Boss Adapter, make sure yours is a direct replacement with same specifications. 9V/200mA. And "tip negative". DO NOT use Radio Shack stuff, nothing against them, but there adapters just don't mix well with Boss products and the like.
2) Try just the battery, no AC adapter. Remember to unplug the input when not in use. Saves battery.
Basic rule of thumb...when using correct AC adapters for all your pedals all the time, and all sounds good, then take out the batteries.
If you still experience problems, it would be an internal IC chip most likely. From there post another question maybe.
Posted on Apr 01, 2010
How do i transfer music from my computer to my mustang l(v.2) guitar amplifyer
You plug into your headphone jack on the computer with a cable that has one jack on each side then plug the other jack into a 1/4 jack adapter & 3.5 mm then plug your guitar cable into the adapter and the other side into your amp
Sep 28, 2014 | Fender Mustang Guitar Amplifier 20 Watts...
Line 6 how do i get it to work
Line 6 connected to AC power and LED showing power to unit. Guitar into effect input, effect output to guitar amp. Does guitar make sound through amp in bypass mode? No then check cables...yes then use foot switch to turn Line 6 effects unit on. Adjust control knobs for desired effect levels/settings.
If pedal provides no effects...off/on switch defective or internal electronics in need of repair.
Oct 26, 2012 | Line 6 DL4 Delay Modeler Effects Guitar
My rumble 30 bass amp makes a lot of bad noise when i plug it in. it started off when i first started playing it and it worked fine, then after a few minutes it started making the noise. i've tried...
How new is the amp?
A single faulty solder can do that...I'd try returning in to the seller.
Have you tried a different amp with the same equipment?
Sounds like a wiring issue.
Hope I've helped
PvT
Sep 25, 2011 | Fender Rumble 30 30watt Bass Guitar Combo...
When I turn on the amp, I get a loud hum. plugging into the jack doesn't change anything. turning the dials doesn't change anything. when I turn off the amp it makes a loud crack.
i) Disconnect one lead of loudspeaker & insert an open-ended guitar cable into headphone socket.
ii) Put a dc voltmeter across open end jack then turn Frontman ON for a few seconds.
iii) The reading should be about 0volts - if the voltage is high (27v), then it is likely that the PA chip TDA1514A has blown.
iv) If,however, the voltage is correct in iii) , then reconnect speaker & put guitar cable into the POWER AMP IN socket & connect other end to guitar...Turn on briefly, if there is still hum then fault is in the output stages & will require chassis removal to solve.
Feb 23, 2011 | Fender FrontmanTrade 25r Combo Guitar...
My line 6 spider III 15 watt amp isnt working properly. i turn it on but i get this sound when its connected to the guitar. it sounds like when a guitar is not connected to a guitar and the guitar cable is...
While it could be true that you're having a problem with the guitar or cable as the previouse expert suggested, to say that it can't be anything else is false. It could be a jack problem...it would only be apparant when the jack is making contact with a cable. I do think you should test it with another guitar and another cable but if that is not solving the problem then I bet it's a problem with the input jack of the amo itself or even one of the ionternal components (this is a digital amp and there are MANY components and settings that can trigger a problem like this) If the problem is not solved with a new cable/guitar configuration then it's time to take it to the shop.
Jul 09, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
My guitar won,t play threw the amp lots oof static
Sep 15, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
May 18, 2009 | Fishman Music
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 | Music
Music Logo
21 people viewed this question
Top AMP Music Experts
Matthew Spark
Matthew Spark
Are you an AMP Music Expert? Answer questions, earn points and help others
