Question about Samsung Vacuums
Beater bar gose on and off like it shorts out samaung canister
When vacuuming beater bar goes off and on Samsung canister
reddevil6
  • 1673 Answers
SOURCE: beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Posted on Jan 15, 2008
SOURCE: Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 15, 2008
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Posted on Jan 01, 2009
  • 3600 Answers
SOURCE: The beater bar won't come back on.
Did you replace the beater bar belt?
Posted on Jun 13, 2009
BElectric
  • 1140 Answers
SOURCE: I ran my vacuum against
There is a switch next to the main power switch on the handle which turns the brushbar on and off. When the beater bar becomes obstructed as in your case, there is a safety feature which cuts power to the beater bar. All that needs to be done in most cases is to turn this switch off and back on again and the beater bar should resume operation.
The beater bar on / off / reset switch is the yellow switch to the left of the main power button if you are standing in front of the hoover:
Reset the beater bar and you should be back up and running.
If you have already done this or it doesn't solve your problem, please post back for further assistance.
PLEASE NOTE: This reset method is for the Dyson DC17 ANIMAL as stated above. If you have a different version of the DC17, please post back for alternative instructions and state which version of DC17 you have.
Hope this helps.
Regards,
BElectric
Posted on Dec 14, 2010
Beater bar turning on and off. Why doesn't the vacuum?
Try wiggling the wire and where the hose swivels to attempt to determine where it may be shorting out. It could be the wire or the plugs where the wires connect if your model has them. Inspect these areas closely to find your short.
Apr 08, 2016 | Kenmore Vacuums
The beater bar works but the vacuum canister shuts off after a few minutes. Then the switch will only turn the beater bar on and off.
You may have a thermal reset in the vacuum motor that shuts the motor off if it gets hot. Clean the vacuum and replace the filters.
Feb 28, 2016 | Vacuums
Beater bar is not coming on- belt is on, canister is empty. Vacuum runs but no beater bar
Remove the beater bar and clean the debris from the bar and the end bearings. Remove the belt (remember how it is installed) and check it for any damaged areas. Make sure the bar turns freely before the belt is attached to the motor drive. Hope this helps!
Mar 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Beater bar not rotating
Remove the screws from the bottom of the power head.
Oct 09, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Smell coming from vacuum when using beater bar
Check to see if the Belt is broke or a build of dirt is were the belt is . Make sure the beater bar is sitting in place .Best of luck Ed.
Jun 18, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Removal of the beater bar for digipro 6900
unscrew bottom and screws on top pull open beater bar just pulls out
Mar 06, 2009 | Bissell 6900 DigiPro Bagged Canister...
Motor on the powermate keeps cutting in and out.
If your talking the motor on the beater bar, then chances are either when the beater bar was attached to the hose near where you hold it, it did not lock, and the connection is intermittent, or the cord has an internal break.
Jan 22, 2009 | Kenmore 22313 Bagged Canister Vacuum
Beater bar
on the bottom take out 2 screws they are closer to the back wheels pull off cover there is a plastic cover over the beater bar take off there is a belt if it broke or wore out change the belt that should fix your problem
Jan 07, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
26 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
ray gallant
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
