Question about Razor Toys
Razor pocket mod seat won't open - Razor Toys
3 Suggested Answers
  • 38 Answers
SOURCE: Bought a razor pocket mod scooter second-hand-it
Use a wedge. Place the thin end between the tire and rim. Then push the tire off using the wedge and your other hand, work your way around the circumference of the tire until it is off. Use the same process to put the new tire on. But this time you will push the tire on the rim.
This is a pic of the ideal tool you should use:
Posted on Aug 13, 2010
emissionwiz
  • 77499 Answers
SOURCE: Razor pocket mod wont start just a green light and a clicking sound I brought a new speed controller but wont start.
Sounds like the battery is defective.
Posted on Dec 04, 2016
Under seat storage compartment jammed shut and won't open
kiki razor scooter storage compartment will not open
Jun 04, 2014 | Electric Razor Pocket Mod Scooter
The seat is stuck shut
it opens from the rear and flips forward
Aug 01, 2012 | Electric Razor Pocket Mod Scooter
Where is the fuse on bella
under the seat you have to remove the screws that hold the compartment on then this will give you access to the batteries and the fuse
May 21, 2012 | Razor USA Razor Pocket Mod Electric...
Bella won't charge
check it with a multimeter and make sure that its putting out the correct amount of volts, it should be at least 24 volts
Razor Bistro scooter won't take charge - light stays red
i had the same problem with mine and it ended up being that one of the batteries was bad, there are two 12v batteries wired in series under the seat, usually you can tell which one is bad by looking at them, one of the batteries will be swelled up
May 09, 2012 | Razor Pocket Mod-bistro Retro Scooter
Razor scooter does not go fast
battery must be bad, there are two 12v batteries wired in series under the seat one or both of them must bad bad so it is not able to supply enough power to the motor. remove the seat cover and visually inspect the batteries and see if one or both of them are bulged
May 09, 2012 | Electric Razor Pocket Mod Scooter
How do you operate Bella mod
there is an on/off switch right below the seat next to where you plug in the charger, then you have to twist the right hand grip
Apr 29, 2012 | Razor USA Razor Pocket Mod Electric...
Toys Logo
93 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
