Question about Avital Vehicle Parts & Accessories
Can I easily swap a malfunctioning Avital 5303i with a 5305L?
I have a 2000 GMC work truck with an Avital 5303i system in it. The remote started operating intermittently and then hardly at all. I purchased new batteries and it didn't help. I purchased a new remote and that wouldn't work so I purchased what I thought was a matching 5303 alarm with the plans of switching out the brains. What I received was a 5305L. I'm wondering how difficult it would be to pull out the 5303 and replace with the 5305. I know there are fewer pieces but I don't have the time to learn to install this so if it's more than unplug and plug I'll probably hire it out.
  • 232 Answers
SOURCE: 2002 Jeep Liberty Limited 3.7 V6 Auto with 4wd- Factory alarm system malfunction
all alarms have disable function usually located down underneath the driver side, look for a small toggle switch or momentary switch, turn the key to the on position , click the switch once or twice to the small red l.e.d light stays on constant.
Posted on Aug 09, 2008
  • 5 Answers
SOURCE: changed batter remote start not working
Hello, What has happened is your remote has lost its programming.. Just like with most electronics, when something is reset or powered off, or even when the battery dies ....the programming software is lost. The remote has to be reprogramed either by a dealer (suggested) or by an aftermarket outsource..Hope this helps...This could help with almost all remotes.
Posted on Nov 22, 2008
SOURCE: F250 Ford 7.3 L Powerstroke Hard to Start Cold
I have a 2000 F250 with Powerstroke and my buddy has a 02 with same engine. Both of us have had the same problem. There are two coils (look like starter coils) on top of the engine that can be seen from the passenger side of the truck. The shorter of the two, has to do with supplying voltage to the glow plugs. When this coil gets older, it breaks down causing a higher resistance in the circuit. Which reduces the volts that the glow plugs see. In turn resembles a problem with the plugs. My buddy and I changed the coils and both trucks start like new. The part cost $80-$90. and can be changed in less than 5 minutes. Glow plugs are a lot bigger job and more expensive.
Posted on Dec 02, 2008
  • 740 Answers
SOURCE: Need to turn the valet switch off On 1999 Nissan Maxima
Look for alarm Brain box and look for wires coming out black and red going to valet switch. to turn valet on turn ignition in ON position and press-switch or flip depending on the type of switch. If it a basic alarm just disconnect the main wiring harness to alarm box- unplug and the car should start. Good luck and thanks for using FIX YA
Posted on Jan 27, 2009
SOURCE: truck just shuts off
I own the same 3500 GMC 6.5 diesel truck with the same problem. We replaced the brain under the upper turbo hood and it fixed it pronto. No more shutoffs
Posted on Apr 01, 2009
I have a 98 GMC Yukon I need to uninstall a 5303 model Avital aftermarket alarm system/keyless remote. I believe it has malfunctioned and is causing my car not to crank. It will turn over but no spark
Try finding it. Under dash probably.. Unplug the two fuses first, sometimes that works, if it's a high end viper or dei unit then you can trace the wires to the starter. #12 gauge wire pink or red. Should see where it's tapped in or relays hidden under the panel. It shouldn't cost too much for electrical guy to find and disable
Sep 08, 2015 | Avital Vehicle Parts & Accessories
2000 dodge durango remote starter
Go here to find wiring diagram for your truck - then you'll know where these wires are
Jul 29, 2014 | 4103LX Remote Start System with Two...
Avital remote start troubleshoot
Reset your PCM codes. Reset security codes -
Mar 07, 2014 | Vehicle Parts & Accessories
Tach and speedo quit working after remote start installed. My 04 yukon's speedo and tach will quit working. I can unplug battery for 5 minutes and will work for a few days. If I turn off vehical o
Well, if you connected the tach sense wire (violet/white) from the Avital, remove it and use either virtual tach or voltage. It sounds to me that whatever you have connected to the tachometer is sending a signal rather than sensing, causing the malfunction.
Jan 20, 2013 | 4103LX Remote Start System with Two...
No lights with avital
If your vehicle parking lights are working at the switch then, the inline parking light fuse(15 amp) of the Avital unit may be blown.
Sep 22, 2012 | 4103LX Remote Start System with Two...
How do i reset my remote start car alarm avital 5303
i have a avital 7352l remote start my fob got smashed under the hood of my car still locks and unlocks car but went to use remote start and it tried to start car but it didnt then i got into my car and try to use my key and it didnt crank at all can anyone help me solve this problem?
Feb 21, 2011 | 5303L Security/Remote Start System
Engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
Jan 28, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
