My washer no longer chimes when I push the buttons. How do I get the volume turned back up?
  • kakima Dec 25, 2016
    Hi Kenda Hootselle, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
How do i turn off the hourly chime for the adidas adp1635?
When you are setting alarm, look for the tiny speaker or volume sign on the so called dial. You must push appropriate buttons till that sign disappears. Then the beep will go off.
Apr 03, 2011 | Adidas Fitness Control ADP1635 WW Watch...
I have a xonix watch that chimes every hour, how do I stop this?
I have just bought a xonix watch and had the same problem. To get rid of this annoying beep I just had to push the 2 bottom buttons simultaneously and it was gone :D
Sep 27, 2010 | Watches
2007 Saturn Aura XE, the audible alarms can hardly be heard
Good news - they're adjustable. The radio is used to adjust the vehicle's chime level. To change the volume level of the chime, press and hold push-button 6 with the ignition on and the radio power off. The volume level will change from the normal level to loud, and LOUD will appear on the radio display. To change back to the default or normal setting, press and hold push-button 6 again. The volume level will change from the loud level to normal, and NORMAL will appear on the radio display.
Note: Each time the chime volume is changed, three chimes will sound to indicate the new volume selected.
Sep 07, 2010 | 2007 Saturn Aura XR Sedan
Tempus fugit westminster mantle battery operated clock has 2 buttons under an H and 2 buttons under an M. how do I set the chimes? Amy Howard
I had the same problem but the solution is unbelievably simple. Just set the hands to the time desired by turning the round button on the housing. Now you mmust tell the quartz timer/clock (plastic rectangular mechanism) the same time as you have set the hands. In this way when the hands hit the Quarter hours/half hours and the hours, the electonic chimes will chime the correct time.
Ultra simple. The two hour buttons and two minute buttons represent a 24 hour clock. Example, how to set the clock to 2:50 PM. Easy, change the 2 PM to its 24 hour counterpart, i.e. 14 hundred hours.
Move the hands to 2:55. Push the first button once for 1, push the second button 4 times, push the first M button 5 times, push the second M button 5 times. Move the set button back to run and there you have it. 1455 Hours. Not it should chime correctly. As a tip, use a brand new fresh battery to try this out.
Feb 08, 2010 | Seiko Mantel Clock
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
My timex indiglo watch beeps on the hour. How do I take it off so it does not beep on the hour?
Thwat is the chime. Some how it must have been turned on. Somewhere on the watch you will see a little bell or wave figure )))) There is 1 of 2 ways that you chime can be turned off. The first way to try is to push both buttons on the right hand side at the same time that should turn off the chime or the alarm, but if you do it more than once it will turn off whatever wasn't turned off the first time you pushed the button, and if you push them again, it will go back to the configuration you started with. The second way would be to go to your alarm modeand push the button that is NOT your light button or your "mode" or "adjust" button and push that button, that should cycle through the charm and alarm as went through before. If you find that neither one of these ways work, send me the model # and I will get you the information you need. PLEASE if you still have problems let me know!! Good Luck!!!
Aug 11, 2008 | Timex Watches
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
WR30 Wristwatch
hello,if you have the little circle window on the left of your face,that will tell you if the alarm and chime are on.
to turn them off you must push and hold the lap/reset button and at the same time push the st./stop button:
1 time takes of the chime-hourly beep
2 times takes off the alarm tha you set
3x's puts the chime back and 4x's puts the alarm back on.
Jul 21, 2008 | Timex 1440 53591 Sports Quotient...
Cant get mp3 to turn on
Try holding in the volume + button and reconnecting it to your computer. Continue holding the volume + button in until the "found new hardware" wizard comes on. NOTE: if you hold the volume + in for longer than 1 minute and no hardware wizard appears, this strategy will not work with your version of Windows.
Apr 08, 2008 | Philips GoGear HDD075/17 MP3 Player
Washing Machines Logo
Top Washing Machines Experts
