Question about LG LMX25988ST Stainless Steel French Door Refrigerator
I have an LG model LMX25988st I replaced the filter and it still keeps saying '0' on the change filter icons on the fridge indicator. How do I get to change that??
2 Suggested Answers
SOURCE: Our fridge is leaking from
our fridge is: GRL207NIS The display reads ; ERR, FF I need help!
Posted on Nov 16, 2010
Hi I have an LG fridge freezer model number GR L206CPQA and there is a horrible smell coming from the water from the dispenser, the filter has been changed and the ice seems to be fine but the fans on the...
Sorry but your model number doesn't register with me in the USA.
My experience tells me that the plastic water line from the filter to the water tank to the dispenser outlet is your problem. Replace those parts and you should be ok.
Hope this helps.
Nov 14, 2011 | LG Refrigerators
Where is the water filter on an LG fridge model # LFX21960ST
Your filter is in the upper left corner of the fresh food compartment.
(See manual link page 7 for picture)
Actual filter change out steps are on page 28 of the first link below.
Your 2.60 MB manual can be found here:
Your filter original part number is 5231JA2006A but has been replaced by PN 9990 and is item 624A here:
Thanks for choosing FixYa,
Oct 03, 2010 | LG Refrigerators
Freezer frost buildup; fan constantly running; water filter
Just had mine repaired. Tech told me that the tempearature settings on the display panel are not EXACT science. The fridge is cooled by blowing air from the freezer to the fridge and when the sensor in fridge reached approx desired temperature, the damper is closed.
The noise you hear periodically (water dripping) is the heating rod melting the defroster (hence frost freeze), which unfortunately sometimes spills into the blower motor to fridge, causing frozen motor, causing the infamous ER FF error code and fridge failure.
I reluctantly had LG to do the energy saver fix (recall) and it replace everything that the internet users are complaining about.
Jun 27, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
This is the indicator that suggests that it is time to change the water filter.
After 5 months of operation, the indicator shows as light pink. At this point, it is a reminder to aquire a replacement filter,
After 6 months of operation, the indicator turns to red. This is now the suggested time to change the indicator.
Even if you aren't using the water, the filter indicator still lights as this is simply a timer and does not measure water flow through the filter.
To reset the indicator, press and hold the Fridge and Power Cool buttons at the same time for 3 seconds. These 2 buttons are on the right side of the display panel. They are the first 2 buttons to the right of this indicator.
Printed on the panel, there is a line connecting the buttons with a miniature of the indicator in the middle. The instruction to hold the buttons for 3 seconds is printed below the buttons.
Because all Samsung refrigerators use a microprocessor to control them, the timing is precisely as given. Since people usually aren't that precise, you may find yourself holding the buttons for 4 or 5 'seconds' before the indicator changes.
Samsung has used a filter indicator like this since the first full-size Samsung refrigerator wa introduced in the United States in Fall 2002. Though the time has varied slightly between models and the 2-button combination has varied even more, the basic process applies to nearly every model that had an ice filter.
Dec 22, 2008 | Samsung RF265AA Bottom Freezer French Door...
How do i change lg fridge water filter
have just changed the filter on our lg fridge, it's not easy: the filter is external, at the back of the fridge. the fridge has to be pulled away from the wall and then the filter can be seen.
Aug 14, 2008 | LG Refrigerators
I purchased a new filter (Model LT600) Part #(5231JA2006B) for my LG refrigerator I installed the new filter and I am unable to set the filter/month button. After installing the new filter the number (1)...
Usually you just need to hold in a reset buttom (or a button near the dispensor for over 5 seconds to reset. The owners manual will tell you (I do not have one). or- Try any buttons you can find.
Apr 21, 2008 | Refrigerators
Daewoo refrigerator water filter red light still on after replacing the filter
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Oct 08, 2007 | Refrigerators
LG LMX25988ST Stainless Steel French Door Refrigerator Logo
32 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
