Question about Poulan PR8527ES Snow Thrower
Where does the traction idler spring connect on Poulan pro snow blower, part # 414557
  • 6 Answers
SOURCE: poulan bvm pro 200 gas blower not getting gas
As a service center for Poulan products the usual problems for not starting I see is compression or the cylinder has come loose from the crankcase. Compression needs to be 115 psi minimum. If you remove the plastic muffler cover you can see the cylinder-crankcase joint. Wiggle the spark plug to look for any movement at that joint. If there is any movement the cylinder screws are loose.
Poulan has an excellent 2 year warranty and any service center should be happy to repair it under warranty for any problem.
Posted on Nov 19, 2008
SOURCE: recoil spring broken
you need to supply the brand and model of the blower so i can look it up
Posted on Feb 15, 2009
bulldogchief
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a Poulan Pro Blower PPB2000LE rope came
It is not a question of clockwie or not, it depends on the direction of rotation of the engine, they are not all the same.
*wind the rope/spring in the direction that the rope would pull the rope rotor.
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Posted on Nov 16, 2009
rycgl
  • 1545 Answers
SOURCE: 25 cc poulan pro gas
If the carburetor is a Zama (and it probably is), then the manufacturer of the carb states these settings:
http://www.zamacarb.com/tipspage.html
Posted on Apr 04, 2011
How to fix electric start on poulan pr270
Sounds like your drive gears on the starter are shot.
I took my starter off and took it to a small engines shop and he repaired it for $25.00. He said i could have fixed it myself but the little springs are hard to line up and you have to know what you are doing.
Mar 08, 2015 | Poulan Pro 27" 2Stage Snow Blower Electric...
Tines wont turn handle grip flopped down no spring tension
Could be your cable has broken or come undone or the spring has broken. I had to replace my cable and had to order this cable and I was in a hurry so I picked up a cable for a lawn mower cut it in half and got a package of wire sleeves and put them on and crimped them with a vice grip.
Machine works good now.
Mar 05, 2015 | Poulan Pro 27" 2Stage Snow Blower Electric...
Poulan snow blower p055te24.auger does not turn.shear pin on auger does not turn.how to get auger shaft off? gbethune10@yahoo.ca
GO TO GOOLGE ANDTYPE IN THE QUESTION YOU TUBE WILL HELP YOU IN THIS PROBLEM I HAVE USED THIS ON OTHER PROBLEMS AND ITS HELPED ME OUT
Feb 10, 2015 | Poulan Pro 24" 2Stage Snow Blower Electric...
Need belt size for poulan pro 96194007 snow blower
Is there a part number on the belt itself? Try googling the model number and putting in belt.
Mar 01, 2014 | Poulan Pro 24" 2Stage Snow Blower Electric...
Starting poulan pro snowblower
gas spark and air , if you have these 3 it will start , which one do you not have
Jan 12, 2014 | Poulan Pro Pr621 21-Inch 208cc LCT Gas...
I am unable to start poulan pro snow thrower. Recoil handle will not pull and electric start wont turn over. Brand new machine, never used. Is there a safty mechenism?
have you ever had it running?
you can check the starter, pulll it off and check gear at the end
if teeth are missing the you have to get them off the magnets on the flywheel. they jam it there giving the indications of a set up engine. I ve seen it 2 times
Dec 14, 2013 | Poulan Pro 27" Snow Blower Electric Start
Poulan Pro snow thrower PR8P27ES Brand new and unable to pull recoil handle or turn over with electric start. is anyone aware of a safty mechenism.
no known safety- did you assemble anything? if not- return it. if you did asssemble anything- slowly go back thru in reverse and see if you have a bolt in wrong
Dec 14, 2013 | Poulan Pro 27-Inch 208cc LCT Gas Powered...
How to adjust the Toro 826 snow thrower
Belts will have spring tension on the idler pulleys.
Both traction and auger control cables will also have cable length adjustments to cause the travel of levers or idler pulleys to tighten belts. Adjustments are commonly located under the control panel/levers.
Dec 03, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Poulan PR8527ES Snow Thrower Logo
62 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
