Question about iPad mini Tablets & eReaders
Speed up downloads & upload on iPad mini 4 loading is slower than a dying snail it seems to take forever how can I fix this?
2 Suggested Answers
AndrexT
  • 14584 Answers
SOURCE: Speed up download & up loading on iPad mini 4
You can't speed up the device only the internet connection. My internet connection also supplies my television signal from Bell so I have 125mbps. It is blisteringly fast. The device you have is only held back by the size of the 'pipe' that the date travels down. Your iPad Mini is plenty fast enough, your internet connection isn't.
Upload a file from home and time it. Upload the same file from MacDonalds when the place is EMPTY and time it. The place must be quiet as you are all sharing the same connection.
Posted on Dec 25, 2016
Dec 25, 2016 | iPad mini Tablets & eReaders
What is my pass code for my iPad mini?
The Pass code for the update is the normal postcode you use when you turn on your iPad. I hope that fixes your problem.
Apr 05, 2016 | Apple iPad Mini
Lost all contacts on iPad mini
If the important contacts in iPad get deleted, you will try to get them back. Restoring iPad with the iTunes backup is the easiest way to recover deleted contacts on iPad mini. If you update your iPhone backups regularly, then you can recover most of the important data from the backup. The restoring process is also easy to be done, and the following tutorial is for the new users of iOS devices:
  1. Connect iPad mini to computer with USB cable, and iTunes will launch automatically. If not, you should manually start iTunes.
  2. iTunes will recognize iPhone and display the iPad icon at the upper left corner. Click the iPad icon.
  3. The control panel of iPhone appears after you click the iPad icon. Click Summary in the panel.
  4. Click Restore Backup in the right part of the window. Then iTunes will allow you to choose the iPad backup, and finish the restore.
Visit here to know more methods about iPad contact recovery.
http://www.leawo.org/tutorial/how-to-recover-deleted-contacts-on-iphone-6.html
Nov 11, 2015 | Apple iPad Mini
How to down load free iOS 7 tommymipod?
This all depends on which iPod you have ....
IOS7 is only compatible with:
  • iPhone 4
  • iPhone 4S
  • iPhone 5
  • iPad 2
  • 3rd generation iPad with Retina
  • 4th generation iPad with Retina
  • iPad Mini
  • 5th generation iPod touch
  • So if you do not have one of these you cannot install IOS7.
  • Mar 02, 2015 | Apple iPad 2
    How to replace I pad 2 broken screen
    Is the screen broken or is it just the digitiser? There are many excellent videos available which take you through the process of replacing all parts of your iPad.
    However, it is not something that can be fixed easily and you need to exercise great patience in dismantling your broken iPad and replacing the damaged parts.
    Make sure you have plenty of space in which to work and place all the parts of the iPad around your working area so they are easy to reach.
    Good Luck.
    Mar 01, 2015 | Apple iPad 2
    Why do I get you tube error loading messages when trying to access you tube videos on my I pad
    Most likely your iPad is full... of pictures, videos, music, etc. Visit the Settings app, tap General, then Usage. In the STORAGE section at the top, you'll see how much of the storage is available on your iPad and how much is used. If the available number is small, you need to remove stuff until you have enough to handle incoming video streams (YouTube, for example).
    The STORAGE section also identifies the apps that are using your space - if Music, Photos & Camera, or other apps seem to take a large portion of the space, either remove some of the data associated with those apps (pictures, movies, music) or remove apps themselves (apps you don't use don't need to be taking space on your iPad).
    Portable devices aren't meant for large permanent storage. You should save things you intend to keep forever on your desktop device or in the cloud.
    Oct 18, 2014 | Apple iPad 2
    Disabled ipad 3
    What wrong with your iPad 3? Maybe you can reply on the tablet replacement repair parts for iPad 3 to make your iPad return back new and health. Nowdays, there are more repair parts for fixing the unflexible and scracked.
    Oct 04, 2013 | Apple iPad 64 GB WiFi
    How do I get my apps from my iPhone & iPad to my iPad mini
    For apps you can:
    If you only want some of your apps, just go to the app store, purchased and select the apps you want. You can download for free on the new device as long on the same iTunes acct.
    For all apps, turn on app share under Settings, iTunes & App Stores, turn on Automatic Downloads for Apps. Turn this on, on both iOS devices you want to have the same set of apps on
    For photos, turn on iCloud Photo Stream under, Settings, iCloud.
    Jan 12, 2013 | Tablets & eReaders
    How do I make the new iPad's battery recharge faster?
    There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
    Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
    I can help you with other things too if you ask.
    Mar 27, 2012 | Apple iPad HD
    Tablets & eReaders Logo
    Top iPad mini Tablets & eReaders Experts
    noel
    noel
    Andrew Taylor
    Andrew Taylor
    Kolbrun...
    Are you an iPad mini Tablet and eReader Expert? Answer questions, earn points and help others
