Question about Cisco Computers & Internet
How to retrieve Cisco router password without losing configuration?
    Habit-Forming:
    Scholar:
  • 51 Answers
Need help to recover the forgotten password of your Cisco router? The following guide will help you restore the password without losing your router configuration. To retrieve the password, you will require rebooting your router many times. It means stoppage, but it is the best step to reset the password. At first, you need to connect the first end of the standard light blue cable to the power port and the other end to the 'Console' port on the back of your router. After connecting the devices, you need to make a serial connection to the router. For that, you need the following settings:
Baud: 9600
Parity: No
Data bits: 8
Stop bits: 1
Flow Control: None
To recover the Cisco router password, check the following steps:-
1.Restart your Cisco router and press the 'Break' key to conflict the boot order. Input config 0x2142. It conveys the router to avoid NVRAM in the boot process. It won't load your current configuration.
2.Enter reset to restart your router. When asked to run the setup process, choose 'No.' Enter 'Copy Start, Run.' It loads the beginning setup into memory.
3.Now, if you enter the 'Show Run Config,' it will show you the router settings. Also, you should consider that the router name is in the prompt rather than the default 'Router.'
4.Type the 'enable secret new password' to change the enabled secret, and then enter the 'config-register 0x2102' to modify the registry settings back to 0x2102.
5.Once your router restarts, it will load the old settings along with the new password. Now, you need to save it so that it will continue during restarts.
6.Enter copy run start. Type Reload at the prompt to reboot the Cisco router.
Now, note down the password to keep them safe. However, if the steps as given above fail to recover the Cisco router password without losing the configuration or you need the help of experts, you can call on the genuine Cisco customer care number listed on the Contactforhelp to get the direct support of experts for recovering the password quickly.
Posted on Aug 31, 2017
  • Cisco Master
  • 15,716 Answers
You can't, otherwise there would be no point in having a password would there!
Posted on Dec 24, 2016
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
This is a twitter about passport.
https://twitter.com/routerswitchcom/status/917935025315651586
Hope it's helpful
Posted on Oct 13, 2017
dante777
  • 623 Answers
SOURCE: I would like to configure port fowarding on the CISCO 857 Router
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Oct 24, 2009
jcoady
  • 79 Answers
SOURCE: password reset of cisco 2800 router
Straight from Cisco:
Password Recovery Procedure for the Cisco 2600 and 2800 Series ...
Posted on Jun 11, 2009
mravikreddy
  • 9 Answers
SOURCE: cisco router startup config
yes thats possible.
Posted on Dec 18, 2008
techjuli
  • 157 Answers
SOURCE: cisco 857 router
You might need to reset the password. In order to do this, follow these directions:
  1. Console into the router, then power cycle it. As its rebooting hit the "break | pause" button on your keyboard, and you get to the rommon1> prompt.
  2. Then type rommon1>confreg 2142 rommon2>reset
  3. The router comes back on as if it were new---answer no to the first question, and sometimes it asks a second question (do you want to terminate autoinstall, or something...)---answer yes to the secondquestion if it asks. Then hit enter and you get router> in a few seconds.
  4. Then router>en router#copy start run
create a new account:
  1. router#conf t
  2. router(config)#username bob priv 15 password bob
set register back:
  1. router(config)#confreg 0x2102
  2. router(config)#exit
  3. router#wr
  4. router#reboot
and that should let you login with bob/bob
Posted on Nov 30, 2008
  • 59 Answers
SOURCE: Motorola..routers with cieso
sure as long as want to configure them for TCP/IP not sure what else you would be talking about other than maybe VPN. I'm assuming the motorola is a cable modem...not much configuring there... more info would be required to be definitive but overall the answer is yes.
Posted on Aug 28, 2007
How do I reset my password?
In the below example i'm setting password as cisco for enable mode & Virtual terminals of router
1)Connect to the router and follow the below steps
Router>
Router>enable
Router#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#enable secret cisco
Router(config)#line vty 0 4
Router(config-line)#password cisco
Router(config-line)#login
Router(config-line)#exit
Router#exit
Router con0 is now available
Press RETURN to get started.
Test:
Router>enable
Password: (type cisco to enter into the router privilaged mode)
Router#
Aug 09, 2015 | Computers & Internet
Tip
Guide to Reset Password on a Cisco Router
How do I reset the password on my Cisco router?<br />I bought a Cisco 1700 router from an auction, but there is a password. How can I reset the router to original factory specifications? <br /><br />Sky sagem wireless router reset password? I just got this sky wireless router second hand and it has a password set on it. i tried to press the reset button at the back but it does not do any thing, it still comes as a password is set.<br /><br />How to reset password on dlink wireless router? I have a dlink wireless router model number DIR 825 . It works good but I am trying to access internet on my ipod and the password i have set is incorrect , this also happened when i tried to access internet on my laptop. When i first set up my ps3 i dont recall having to put a password in but this was when i first got the router. How do i reset the router password or find out what the password is AND if i reset the password or reset my router will my ps3 have to be reconnected or will it stay?<br /><br />How to reset password on a router? I recently acquired a linksys router (used) and need to know how to reset the password so that I can use it. Also, is there any way to modify a router to be useful as a cell/wifi blocker, or as a signal booster?<br />... <br /> ----From Yahoo Answers<br /><br /><br />To reset password on a Cisco/D-link/Linksys/Netgear router is a very common problem among people who want a secure network environment for surfing on the internet. If you are confused with the complicated procedure to reset or change the password on a router, or if you are trying to configure a Cisco router, but a password is blocking you from enable mode, don't worry, just do the steps as follows, password reset on a router is no longer upset to everyone.<br /><br />First, be informed that what you need:<br />.<a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router</a><br />.Computer<br />.Internet Connection<br />.Blue Serial Cable<br /><br />Guide for You to Reset Password on a Cisco Router:<br />1. Download a program called Putty from the first resource site below. PuTTy is a terminal emulator application which can act as a client for the SSH, Telnet, rlogin, and raw TCP computing protocols (PuTTy on Wikipedia).http://en.wikipedia.org/wiki/PuTTY<br /><br />2. Connect one end of the blue serial cable to the Cisco Router and the other to your computer. Open up the Putty program on your computer and select the radio button next to "serial" on the right-hand side of the start window. Click on the "Open" button in the bottom right-hand corner of the Putty start window to open the terminal.<br /><br />3. Power the Cisco Router on. As soon as the router begins loading in the green and black Putty terminal window, press the "Ctrl" and "Break" keys simultaneously until its going into rommon mode.<br /><br /><br />4. Once in rommon mode, you have to change the configuration register number to make the router boot from a blank configuration file. For the 2800 series Cisco Routers, the command "confreq 0x2142", changing the register number to 2142, worked. Search on cisco.com for information on your particular <a href="http://www.router-switch.com/Price-cisco-routers_c1">Cisco Router Series</a>.<br /><br />5. Type the restart command in rommon mode, which is "reset". This will boot the router up again. When it is finished, you should be able to type "en" to get into enable mode without a password.<br /><br />6. Once you change the running-config in RAM and save it to the startup-config in NVRAM, remember to change the configuration register number back to its default (usually 0x2102). This is important if you change anything on the running-config. <br /><br />Easy five steps help you finish resetting password on a Cisco router. Easy instruction, easy to follow. <br /><br />
on Jul 19, 2011 | Computers & Internet
Cisco E3200 router configuration lost
The Cisco connect software came on the CD in the box with the router. If was used to configure the router when new. This can be used to fix the router now. I could guide you through a manual configuration but the software is a much faster easier method. I would recommend you try that route. Get the CD and run from there if you are worried about phishing.
Feb 12, 2014 | Linksys by Cisco Linksys E3200 Dual-Band N...
Have a linksys router trying to connect need default password or cisco password
By default, the router has a SSID ID of 'linksys', with *NO* security, and *NO* password. Configure the router to enable security, and to set the SSID and to set a password.
Sep 15, 2012 | Linksys E2500 Wireless Router - Ieee...
Cisco Unified Communications 500 Series reset password with out losing my configuration
if you are talking about your enable password you will have 2 choices which are a factory reset or evoke ROMMON. The simplest way is to backup your running config via TFTP or do a #show run and copy and paste the whole config to a txt file and then reset to factory default and then just load(or paste) that config and then do a #copy run start.
Nov 17, 2011 | Cisco Unified Communications 500 Series...
I have forgotten my passwork to my wireless cisco linksys E3000, how do I go about retrieving it?
he WEP key is defined by the person who set your wireless router up. You will not be able to find out what the WEP key is, but you CAN change it if you have physical access to the router. If you are trying to connect to your wireless router and can't remember the WEP, then walk over to the router and on the back or bottom of it is a small little hole that you can fit a pen or paper clip into. Press the paper clip into the little hole for 10 seconds and release. This will reset all the settings on your router back to default and will allow you to access your wireless connection.
Note: doing this will take away all of your wireless security so make sure that you know what you're doing before messing with it!
Thanks and please rate if this helps you at all :).
Mar 29, 2011 | Cisco Linksys Refurbished E3000...
I forgot to change the default public credential User: cisco and pwd: cisco. Un fortunately I did restart the router. I would like your assistance to gain access to the router or to reset it back to...
Here is a cisco page that goes over the password recovery procedure. Once you reset the credentials, you can make any configuration changes needed. You will also have the option to keep the existing configuration in place but change the password, if the configuration has any use to you.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00801746e6.shtml
Mar 11, 2011 | Cisco (1841) Router (cisco1841)
Password retrieval. Cannot remember the password and I need to hook up a new Mac computer to my wireless network with my Cisco Valet M10 router but do not want to disrupt my current hardware. Thanks
it has a reset switch at back u have to reset router back to factory settings
use the manual for more details and password
then after resetting the router you have to again configure its setting as your needs
Once you reset the router your configuration will be lost and you will have to re configure it
Jan 07, 2011 | Computers & Internet
Computers & Internet Logo
151 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
