Question about Ovens
Why dont are gas stove oven light up whirpool brand stove elect igintor
The ingintor is working but no oven yet wont ingintite
  • 10 Answers
SOURCE: burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Posted on Nov 19, 2007
  • 1314 Answers
SOURCE: Magic chef oven wont turn on
yes oven ignightor to confim this try broil if it lights then its bottom oven ignightor get back wit me ill outline procedure
Posted on Dec 29, 2007
SOURCE: Tappan gas stove,oven not lighting
i am unable to use my oven on my tappan gas range. every other part of the range works wonderfully. the oven just will not light
Posted on Sep 11, 2008
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
SOURCE: whirpool gas stove super capacity 465 the stove
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Posted on Apr 09, 2010
Cant get oven to turn on. the only thing that works is the stove top n have to light it my self. My electical screen wont turn on which controls my oven
Check and see if the stove is plugged in. I suspect your DSI module has failed.
All these stoves ain't the same nor do they even work on the same principle. I am guessing from the picture you have a DSI system. For a more precise answer always post a mdle number. Most model numbers are posted on the oven frame of the lower drawer.
Here is your DSI service Manual
Dec 21, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
Jan 16, 2010 | Ovens
Stave works but oven wont light,not getting gas
May be your ignitor. You'll need to replace this to get it to work. Hope this helps you.
Aug 14, 2009 | Whirlpool SB160PEE Gas Single Oven
Burners and oven will not heat
Something is stopping the gas flow. Turn off gas. Disconnect line from the stove have someone turn on and off the the gas just for a second.(make sure no flame in room). See if gas is available.If not it is the gas line leading into the house somewhere,not the stove.  Follow the piping to the first thng it comes to. Disconnect that line and see if it is open from there back to the connection. If you finally get to the valve,which I dont think you will . You will have to disassemble  or replace it.
Dec 10, 2008 | Tappan 30IN ELEC IGNa Oven
Oven Stops Heating
try it on broil and let me know what it does i dont think its a sensor as they check their selves and set a code most of the time
Feb 15, 2008 | Ovens
Burners on gas stove work but oven and broiler not working
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
HOTPOINT ELECTRIC STOVE
two things---when you open the oven door do you see a button on the right or left side?if so thats a door switch and if its bad you will get no voltage to the element.the next thing is your hi limit is bad.this is a sensor that monitors the temp of the oven and if its bad you wont get any heat.some hi limits reset themselves others you have to manually reset them.let me know.
Jul 30, 2007 | GE JKP15 Electric Single Oven
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
