Question about PfaFF Sewing Machines
I got pfaff expression 2 not stitching i have rethreaded changed needle reloaded bobbin cleaned out all of bobbin area
  • PfaFF Master
  • 12,053 Answers
If the thread is not picking up the bobbin thread and you have installed a new needle, then your machine is not in time. Search for sewing machine timing or take it for service.
Posted on Dec 25, 2016
Zig Zag stitch isn't consistent top stitch is sporadic
Remove all the thread from your machine. Make sure to clean around the feed dogs and bobbin area. Loosen the top tension disk all the way to zero & raise the presser foot. Dampen a piece of pearl cotton with rubbing alcohol and pull the pearl cotton gently down between the tension disk a couple of times. Consult your owner's manual and oil as instructed in the manual using ONLY fresh good quality sewing machine, applying 1-2 drops each spot indicated. Install a brand new needle. Avoid old, fuzzy, or bargain bin thread. With the presser foot in the RAISED position, rethread the top thread--verify it is threaded correctly. Reset the upper tension to about halfway between the high & low number. Make sure the bobbin case is threaded properly and verify the bobbin is turning the correct direction in the bobbin case. Install bobbin case in the machine. Test stitch on a scrap piece of fabric.
If it continues to malfunction, you may need to take it for service.
Dec 29, 2015 | PfaFF Creative 7570
Pfaff quilt expression 4 0
Not sure what the problem is but you might try this:
Remove the top thread completely from the machine.
Make sure the machine is cleaned under the needle plate, the hook/bobbin area, the feed dogs, etc.
If your manual instructs oiling, do so as described.
Confirm that the feed dogs are in the raised position.
ALWAYS RAISE the presser foot then rethread the top thread from the beginning.
Verify the thread path is correct.
Confirm the needle is installed correctly (does the flat part face the right direction?). Is it the right needle for your machine.
Set the top tension to the midway point.
Check that the stitch length is set to at least #2.
Re-test your machine. Tweak the top tension until the top and bobbin threads meet in the middle of the fabric.
Some machines have a presser foot pressure adjustment that increases or decreases the amount of pressure the presser foot applies to the fabric and the feed dogs. You may need to increase this pressure.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjUwYDwuKjVAhULwFQKHRLIA1YQFggmMAA&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2Fexpression-line%2FManual%2Fexpression-3-2-4-2-manual-EN.pdf&usg=AFQjCNFFR0YpgCUh8R92wNbPzlJpuzWVNw
Jul 26, 2017 | Sewing Machines
Pfaff grand quilter
try a new needle
rethread the machine top and bobbin
clean under the needle plate and in the bobbin area for lint
and if these suggestion don't help, then it would be a good idea to have the machine checked.
Nov 11, 2013 | Sewing Machines
How can I factory reset my PFAFF 7550 sewing machine ?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Feb 28, 2013 | PfaFF Creative 7570
Thread on the bottom side of stitch is all bunched up
1. Change needle
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
Oct 09, 2012 | Sewing Machines
Message remove thread jam under the stitch plate keeps appearing! It's clean!
After cleaning out the bobbin area, re-threading the top thread, turning my Pfaff 4.2 off and on it still said " remove thread jam under the the stitch plate". I pushed the "ok" button and it started working again.
Keeping my fingers crossed.
Aug 13, 2012 | Pfaff Creative 4.0 Sewing Machnie
Sews small stitches on the top and loose stitches underneath from the bobbin.
change needle
change your stitch length dial to a number higher like if it on 3 change it to 4 or 5
change the tension to 3 or 4
clean under the needle plate where the feed dog is for lint
clean the bobbin area for lint or loose threads
Nov 22, 2010 | Baby Lock Ellure
My Pfaff expressions 4.0 says Remove thread jam under stitch plate when I try to wind a bobbin, and the machine has no bobbin or thread there, and it is brand new. (and the dealer is closed). Help!
Open the needle plate and check this area for an obstruction.
Refer to the manual for how to clean this area so you get everything back in place.
Mar 19, 2010 | Sewing Machines
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Stitches not even
the needle bar on my sewing machine is loose not sure how to adjust will not go through the fabric to grab the bobbin thread
please help
Aug 31, 2008 | PfaFF Sewing Machines
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
