Question about Frigidaire Ovens
Frigidaire RSE37BAL*0 electric stove..cookies burn on outside/bottom, raw inside...put oven to 500'and element is all lit so whats wrong?
    Top Expert:
  • Frigidaire Master
  • 50,326 Answers
500 is way to hot for cookies . try 350 .
Posted on Dec 25, 2016
Testimonial: "lol....i did bake at 350, so then AFTER i was done baking, i turned it up to 500 to see if my element was working correctly and it was all lit, no "out" parts in the coil.."
  • ray gallant Dec 26, 2016
    then try lower like 325 and get an oven thermometer so you can see if the settings are right
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Oven burns in back and raw in front
That oven is very poorly rated and is prone to a lot of repairs. Most people advise to get something else. There is no common solution. I am sorry.
Feb 15, 2013 | GE Profile JTP56 Electric Double Oven
1984 stove, fuses located on the top of stove/ 30amp keeps blowin
It sounds like the element has a short in it. unplug the range, and take the element out and inspect if for burn marks. check the wires going to the element to make sure they have not shorted.
Jul 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Hi i have a very old 1970? whirlpool electric single oven
It sounds like you burned out the oven heating element control board.
Jul 18, 2017 | Whirlpool Ovens
My electric stove element does not come on
either the stove element control for that particular burner is bad or that element ring is bad or a wire is off or burned on this circuit
Oct 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
The Bottom oven element has burned out. Is is
It's replaceable,if it's an exposed element meaning you can look in the oven and see the element you can do it yourself unplug the range take out the two screws securing it pull it slowly toward you,unplug the two connectors and put in the new one,if it's a hidden bake meaning you can't see the element you would be better off having it done.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
41 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
