Question about Cell Phones
Setting up wi fi keeps telling ngs me connect fail
SOURCE: itouch wi-fi connection problem
Try this one : It worked for me.
Posted on Apr 18, 2008
  • 4338 Answers
SOURCE: iPhone 3G keeps saying 'bluetooth unavailable' and 'No Wi-Fi'
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Posted on Jul 24, 2009
  • 20 Answers
SOURCE: could not connect to the internet using wi-fi connection
need to configure modem/router. just put ip address off modem into address bar on web browser. use admin as name and password for password. Check out and all info will be easily found to solve problem.
Posted on Oct 26, 2009
  • 316 Answers
SOURCE: I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
Posted on Jan 08, 2010
  • 114 Answers
SOURCE: I had recently purchased Samsung
Dear Meghna you have not mentioned the wifi router make and moel
no problem
for this you have to go to your router web admin to add your device as WPS client this will solve the problem
for that all the models are differently configured so you have to try playing with the settings yourself, if you jumble up the settings of you wifi router there is a reset switch in all the routers that restors your router to factory settings.
if you find my information useful dont forget to vote me with the thumbsup thankyou and take care Gagan Gupta
Posted on Mar 15, 2011
How to connecting wifi networks
Hello Pavan kalya naidu,
Please go to mobile setting and turn on wi-fi on your mobile phone.
Now wi-fi network is on.
below your are showing wi-fi connection names.
now click on wi-fi connection and connect.
now asking for password.
enter correct password and click ok .
now your wi-fi connect on your mobile phone .
Mar 18, 2016 | Cell Phones
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Tell me how i resolve dns failed connection
ou can try these options. Please follow step by step instructions on your phone.
A. Reset Wi-Fi:
  1. Delete all the configured wireless connections.Settings-> Connectivity -> Wi-Fi -> Select Network
  2. Click on Forget
  3. Do this for all your connections
  4. Now Enable Wi-Fi again. And connect to router.
B. Using Static IP Address:
  1. Settings-> Connectivity -> Wi-Fi -> Select Network
  2. Make sure to disconnect the network if connected.
  3. Now open the network,
  4. Select Static IP
  5. Now you can assign IP Address
  6. Here are default ips (It may vary according to your router)
    IP : or
    Subnet Mask :
    Default Gateway : or
    DNS: any two of these =>
For screenshots visit
Aug 12, 2014 | Samsung Wave 525 Cell Phone
Wifi will not connect
The below info is from user manual ... downloadable version @
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Jan 17, 2013 | Pantech Pocket
My new zte v9 wont connect to the Internet
you can access the Internet through the mobile network or via Wi-Fi.Your mobile network settings are pre-configured by your serviceprovider and there is no need to change any settings. Wi-Fi Wi-Fi provides wireless Internet access over distances of up to 100meters.1. Tap Home > Settings > Wireless & networks .2. Select the Wi-Fi check box to turn Wi-Fi on
Dec 02, 2012 | ZTE V9 Smartpad Android Internet Tablet
How to connect wi fi for c2 03
how to setting wi-fi
Mar 28, 2012 | Nokia C203
I can not connect to internet in my android mobile, how to set for internet setting, Please tell me.l.
You need to have either a wi-fi or 3g/4g connection and a browser installed on your phone. No other setup is required
Mar 16, 2011 | Google Android
I have Samsung Star Wifi S5233W, everytime i go for internet connection is always fail, and it shows DNS failed, can you help with this problem
Hi.. All you have to do is go to browser, then setting, then clear cache, empty cookies and delete history.. then restart your samsung star, then connect to desire wifi connection. then browse after setting up your browser profile. this work on me all the time.
Dec 23, 2009 | Samsung Star GT-S5233 Cell Phone
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
