Question about Acer 4220-2346 Notebook
I got a new acer aspire 5335 and it's bluetooth is b't working
When i click on the bluetooth button it display's that no blue tooth device found
  • 184 Answers
What do you want to use the bluethooth on? check the device you want to connecty to your laptop and make it searchable to all
also enable pairing so you can pair it with your laptop. both devices must be on and searchable for it to work. some devices turn off visibility after a timed duration. check that too. also some devices are not just compatible and may not be reached by some devices.
Posted on Jul 21, 2009
I am using Acer Aspire 3500. I have a bluetooth button next to my Lan button. The Lan works but the bluetooth says on screen 'no device'. There is a blue tooth symbol next to clock on taskbar on screen...
In order to use the Bluetooth connection, you have to have a Bluetooth device to pair with your computer. Put the device in pairing or listening mode, then right click on your Bluetooth icon and choose the option for searching for a device. (You may be required to enter the device's passcode -- if you don't know it, try 0000.)
Dec 27, 2010 | Acer Aspire 3100-1405 Notebook
How to use bluetooth device in acer aspire 5745.
first the blue tooth device need to be installed , meaning to have the driver for the device ...after that from the blue tooth button you turn it on ..and the device could be find on any other device with blue tooth and be chosen to receive data ..the same way arround..if you open the blue tooth ..you can search for devices ..and choose data to send to devices found in the area..
Oct 01, 2010 | Computers & Internet
NO DEVICE
the machine doesnt have a blue tooth device installed thats all,They make the machines with the option of expanding to new device functions as standard then they can add the components you need ie blue tooth,theres a button but no device installed,you will have to buy a blue tooth device to install on the machine,
Hope this helps Misterdj
I brought a set of dongles for my bluetooth function for about $25 NZD recently,Cheap and cheerful but has limits too so check out the functions you want with bluetooth and go shopping,
May 05, 2010 | Acer Aspire 4720 Notebook
Blue tooth buton not active does it have blue tooth or is that just a button
Try installing the bluetooth driver from the driver disc that you should get when you bought the laptop. If it says bluetooth device is not found, push the bluetooth button once and try again. If it still says that the device is not found, then most probably your laptop have no bluetooth.
This is true for some Acer laptops that I've meddled with. I did what I said, assumed that there's no bluetooth device, only to have it confirmed by the owner that the seller already mentioned that his model have no bluetooth.
Apr 11, 2010 | Acer Aspire 4730-4947 Notebook
Is Acer Aspire 4720z equipped with a built in blue tooth device
The quickest and easiest way i have found is to press the Fn button + the one that turns on your wireless networking if you have one.
But i looked up your system and it says it comes with blue tooth.
"Communications Intel® Wireless WiFi Link 4965AGN network connection supporting 802.11a/b/g/Draft N wireless LAN, Acer® SignalUp technology for enhanced antenna efficiency
or
Intel® PRO/Wireless 3945ABG network connection supporting 802.11a/b/g wireless LAN, WI-FI CERTIFIED™, Acer® SignalUp technology for enhanced antenna efficiency
Bluetooth® 2.0 + EDR (enhanced data rate) wireless PAN (select models only)
Gigabit LAN, Wake-on-LAN ready
V.92 56Kbps* data/fax modem, PTT (postal, telegraph, telephone) certified in select countries, Wake-on-Ring ready
Acer® Video Conference with integrated Acer® Crystal Eye webcam supporting Acer® PrimaLite technology, which consists of a premium sensor, firmware and lenses to provide superior video performance under low-light conditions (select models only) "
I found this here
Feb 27, 2009 | Acer Aspire 4720 Notebook
How do i turn the bluetooth on in my computer acer aspire 5520
Does it have blue tooth? Click "Start", "Connect to", "Blue Tooth", If that does not work, go to "Control Panel", then it should be there somewhere...
Jan 18, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire 6920
go into control pannel, blue tooth devices look through the fomats and if you have bloue tooth it will show up. set up and go. is it 6920G its there
Jan 10, 2009 | Acer Aspire 6920 Notebook PC
Bloue tooth acer Aspire 3680 not work
could be that your acer aspire 3680 actually doesn't have bluetooth. they use a standard case for most of there laptops. it has the button for bluetooth but it doesn't have the actual bluetooth card or required hardware.
Sep 17, 2008 | Acer Aspire 5050-3242 Notebook
Blue tooth device is not working
hi,
check if your device is enabled, you can do this by ---
right click my computer..-> properties--> hardware tab--> device manager --> right click on the blue tooth icon and clcik properties. --> check if enabled..
if it is enabled check if bluetooth is enabled at startup { type msconfig in RUN in start menu, click startup tab..check if it is enbaled in startup}... or else you have to manually switch on bluetooth each time u intend to use... hope it helps.
hope to get rated as helpful...
regards
bzoy
Dec 31, 2007 | Computers & Internet
Bluetoooth on acer 5052ANWXMi
hi there,
i have a new acer aspire 5052, i have installed windows xp,
the problem is that cannot install bluetooth, i get errors like "Device not found"
and when i switch on the bluetooth button, the display shows "no device"
your help will be greatly appreciated
kesava rao
Nov 30, 2007 | Acer Aspire 5050-3242 Notebook
Acer 4220-2346 Notebook Logo
962 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
