We have a cd/dvd player which B and O attached to theback of our Beovision tv. CD won't eject. Any ideas, please.
SOURCE: jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Posted on Jan 24, 2009
  • 33 Answers
SOURCE: cd in car player will NOT eject -any ideas ??
The only way to fix your problem is to have a radio repair shop take it apart. You cannot fix this on your own. Remove the radio or get a quote from a repair shop first. If you cannot find a repair shop , talk to the parts guys at you local ford dealer about sending it out for repair.
Posted on Feb 13, 2009
  • 2653 Answers
SOURCE: cd stuck inside laptop
There is a small hole, usually near the eject button. Unbend a paper clip and carefully push the paper clip into the hole, try to keep it straight. drive should pop right out.
Posted on Feb 20, 2009
  • 6784 Answers
SOURCE: cd won t eject from 2006 Ford Focus mp3 player Get
HI, either the deck assembly is jammed or, the load motor has failed. In this case, you will need to disassemble the entire set in order to retrieve this CD.
The actual loading deck(the part where the CD is located), is surrounded by a metal housing. the gear assembly is probably locked, due to this jam or failed load motor. This will also require a set of precision tools as well. if you find this a bit overwhelming, i suggest taking this unit to a local automotive audio shop. they can dissemble it and, retrieve the CD for a small price.
Posted on Jun 21, 2009
  • 3866 Answers
SOURCE: CD does not eject from my VM 9410 Car DVD Player
it probably got jammed in there what you can do is unplug the power source and replug it back in a brief power push should eject the disk. make sure you have your unlock codes as the unit may think it got stolen if you undo the power. if that does not work to get it fixed around $89 bucks Thanks and please rate
Posted on Aug 18, 2009
Dvd player
hey, have you tried to unplug the dvd player for a while, also hold down the eject button on the player, if there is a small hole in the tray use a needle or other small object to eject the tray,
Sep 03, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
How to eject dvd from tv set
If the loading belt is broken the CD inside will not eject. If the loading motor is defective, the CD mechanism won't eject. Anyway, the CD loading mechanism is defective.
Oct 10, 2014 | Televison & Video
Can't get green standby light to stay on, so can eject DVD from combined TV and DVD player.
First try unplugging and plugging back in then remove caseing and insert paper clip under locking mechanism and hit eject...your locking mechanism signals that there's no cd in it and so to it there's no dvd or cd...hope that helps:)
Jan 04, 2012 | Televison & Video
CD stuck in DVD player in tv
I'm sorry that the disc tray is not ejecting. Please check whether you're able to locate a small hole under the tray opening area. If one available, please insert a pin and it will eject manually now..
Dec 18, 2011 | Televison & Video
Dvd will not eject when using eject button.
I am going to sandbag it. I can use that particular cd to workout with. I will just attach a dvd player separate since most postings can't use the dvd anyway after they get the cd out. Thanks for the help anyway! Susan
May 27, 2009 | Mintek LCD TV Progressive Scan DVD Player
There s a cd stuck inside the dvd player of my tv and wont eject.
Check the mechanism of your DVD player try Repair and Align it
Nov 13, 2008 | Polaroid 3211TLXB 32 in. LCD Television
A friend gave me a gift of CH-DVD 300 player.It is brand new.I opened it and got it connected to my TV.I inserted a photo CD in it.I viewed about 150 photo slide show very nicely.With the remote I tried to...
Greetings Ranin,
I would try unplugging the unit for approximately 30 minutes to allow it to completely power down and then plug it in again. It might restart the internal menus and allow the dvd player to eject.
I hope this helps!
Go Ahead. Use Us.
Jun 25, 2008 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
